Question about RCA 32F531T 32" TV
Ok my tv is off the remote or the power button
My tv is off the remote or the power button will not turn it on.. it was on then shut off on its own i turned it back on it stayed on for an hour or so then shut off and now cant turn it on at all the power button is on and red i have no clue
  • 203 Answers
Sounds to me like maybe the power supply in the unit died. I think your only option might be a repair center. See what the repair is going to cost and weigh that on the cost of a new TV. May just be time to upgrade
Posted on Sep 27, 2009
  • RCA Master
  • 8,457 Answers
Ur high voltage,was dying now it dead,the FBT,the flyback transformer is dead.The big plastic block with a red wire with a cap hook to ur CRT(ur tv tube).
Need remote code for Vizio D32h-CO. No remote for TV. Have Dish remote
For my universal remote control's manual, all of the VIZIO codes are:
11758
13758
12757
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
Jan 18, 2018 | Vizio Televison & Video
Am trying to reset my panasonic TV using the RM V310 I was shown to press the SET button then the POWER button and release ....then the TV button ...then the +Ch and the POWER button back an forth until...
he remote control shluld be checked for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 03, 2014 | Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
I lost the manual I need instructions to program it
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thank You
Sep 12, 2010 | Hitachi VT-RM294A Remote Control
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
RCA 32F531T 32" TV Logo
107 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
