Question about Apex Digital PD-450 Portable DVD Player
APEX PD480 DVD/CD player
Will play CDs but when dvd put in keeps loading for about 1 min. then displays BAD DISK
What could be wrong?
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
SOURCE: Bad Disc - CH-DVD 300 DVD Player Problem
Goto the following site: http://www.drx9000repair.netfirms.com/#Cyberhome%20CH%20300 You more than likely have a bad power supply. The caps in the output circuit are pretty crappy and are well known for failure. Good luck! Art
Posted on Aug 22, 2007
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Loading Problem
No Disk issues on device players like DVDs are caused by the following problems
Dirty Play Heads (Optical lens)
Bad CDs or scratched CDs on the surface
Non Compatible CD formats such as DVDs that are designed for some geographical regions and play formats
Also low electrical current is a major problem too
Your issue could reside amongst any of these problems
Check your DVD compactible play formats if its compactible with the CD you want to play.
If its compactible, then I suggest you get a CD Cleaner to clean to clean to Lens.
Also check your current output and if low, get a voltage stabilizer
Check the surface of the CD if its scratched and get a replacement.
May 25, 2009 | Philips LX3600D System
Apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Thanks,
May 23, 2009 | Apex Digital AD-1110W DVD Player
Certain cds won't run system says loading then says wrong disk
some cd players will not play cdr cds look for cd player info it will tell
you which cds you can play or not.
Mar 16, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Displays "NO DISK"
The message indicates that the system failed to read the index portion of the disc. Try cleaning the lens using a cotton swab and alcohol. Try playing a music CD as well. If hte CD plays but the DVD continues to fail, you have a failing optics assembly that needs to be replaced. This is the most common symptom of failing optics. DVDs will fail while CDs will play.
Keep us posted.
Dan
May 29, 2008 | Apex Digital ADV3800 DVD Player/VCR
WHY WON'T MY DVD PLAYER WORK?
you can try this unplug the unit , you'll need alchohol, q-tips, screwdriver open it and look for all the flat cable connectors. be carefull and remove 1 side at the time ,and clean the contacts, put them back on , see if you can see the optic laser inside the mechanism it looks like a crystal eye, if you can reach it be gentle and clean the dust may it have. or buy at radio shack a cd cleaner. if after that your dvd don't work with dvds try a regular cd. if it plays music the laser its bad nothig else you can do. cheaper to buy a new one
Jun 10, 2007 | Apex Digital AD-1110W DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
My DVD player does not play VCDs or music CDs
replace spindle motor,so i think ur problem vill b solved.. no need 2 change th lense..
Jan 01, 2007 | Philips DVD 622 DVD Player
Apex Digital PD-450 Portable DVD Player Logo
412 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
