Question about Radio Communications
Daewoo lanos 2001 1.4 model immobilizer fault code p1626
Do you have any knowledge of where to get a wiring diagram for this have one for earlier model but no use this is the s model lanos with noabsno remote central locking and the ecu is mounted on the bulkhead under the bonnet not under the drivers seat.Or for a fast fix do youknow howto bypass this system.
  • Richiekis Mar 16, 2008
    Daewoo lanos 2002 1.3 modell p1626 code immobilizer no responce. Dealer said the unit and a key are fine guess maybe wires problem.Issue has not solved engine dos not start.
  • 13 Answers
SOURCE: 2001 daewoo lanos unlock code
you need to take the radio out to get the serial number off the bottom,then google car radio codes,choose make and model and follow the will cost about £8-£15 depending on where you get the code from?hope that helps?
Posted on Mar 08, 2008
  • 62 Answers
SOURCE: Audi fault code J386 (2002)
There's a TSB on that problem. It involves broken wires in the A and B pillar from the central convenience module to the rest of the car. Ask your VW dealership or what not for a more specific answer.
Posted on Jan 13, 2009
  • 93 Answers
SOURCE: changed the battery in the central locking / alarm
press buttons reapatedly to reset
Posted on Mar 06, 2009
  • 83 Answers
SOURCE: 2001 saab 9-5 electric door lock system does not function
Most likely you have a bad TWICE unit. it is located under the driver's seat, at a low point in the floor and often gets wet.
Posted on Mar 25, 2009
SOURCE: I dont know where to hook up immobileizer bypass wire
An immobilizer bypass is an electrical circuit which allows current to flow to whatever component is starved of current to keep the engine from running (usually the coil). The immobilizer opens the circuit to the coil, the immobilizer bypass closes the circuit to the coil.
If you didn't install an immobilizer circuit, then you don't need the bypass. There are probably instructions you missed in the manual explaining the immobilizer circuit.
Posted on Apr 30, 2009
Which is the color and position of the daewoo lanos 2001 camshaft wiring circuit
Note the diagram. The black wire is ground. The pink wire is voltage, fuse protected circuit, hot with key on. The brown wire with white tracer is signal wire goes to computer.
Mar 18, 2016 | 2001 Daewoo Lanos
Timing belt diagram 2001 lanos
As you haven't said what engine you have, here are the diagrams for the 1.4 1997-2003 and the 1.6 1997-2001
25509670-3rwylk0kdq3mwjjzpclkghnz-4-0.jpg 1.4 Lanos
1.6 Lanos
Hope this helps
Mar 03, 2015 | 2001 Daewoo Lanos
Help!!!cant find what fault code means
P4040 code that is a non specific code that could be either EGR control circuit malfunction or security shut down mode meaning that the security system is shutting off the spark and/or fuel.
Sep 20, 2014 | 2001 Daewoo Lanos
2000 daewoo lanos spark and fuel but wont inject fuel
Check vehicle ECU for faults or any vehicle immobilizer.
Nov 03, 2012 | 2000 Daewoo Lanos
Need radio code for 2001 daewoo lanos
Hi Palmspringsv,
I recently had a Lanos towed into my repair facility with a dead battery. After replacing it we had the same problem,radio displays the word code. I found a website that posted the following codes as the most common for the US models. I entered them until I got down to 13th one and it unlocked it. Good luck,hope they help,Chuck.
4316 2152 4513 4362 1156 2145 3451 6361 5624 5241 3346 1165 3241 4524 5436
Sep 16, 2011 | 2001 Daewoo Lanos
HELP! I have a Daewoo Lanos(1998-99), ive got a
The fault code 53 is an ECM IMMOBILIZED ERROR.
The immobilizer anti-theft system thinks the key is invalid. If it detects an error, it will;
Disable the fuel injector circuit--- Disable the fuel pump circuit---Disable the ignition coil.
Code 53 will set when:
1- The Eectronic Control Module (ECM) does not receive the signal from the Immobilizer Control Unit (ICU) within 0.9 seconds when vehicle is stationary, or 1.8 seconds when vehicle is moving.
2- The ICU sends the ECM an incorrect release message more than 5 times.
3- The above conditions continue until the ignition is switched off.
I hope this helps.
Aug 24, 2011 | 1999 Daewoo Lanos
For my2000 daewoo lanos-all the lights and radio turn on but engine doesnt turn over. had battery checked, good. fuses are good.
there is probably a fault with the immobilizer system.
The car should be towed to a shop to check the immobilizer system and to reprogram the keys.
I think this will solve your problem.
Jun 25, 2010 | 2000 Daewoo Lanos
2001 Daewoo Lanos Fault 63.58X 'B'
DTC 63 Will Set When
No voltage is supplied by the ECM through the EST “B” line while reference pulses are received by the ECM from the crankshaft position sensor
check white wire terminal B on ignition coil to ECM terminal C14 for open circuit or short to ground while disconnected if thats ok check for voltage signal at B while cranking no signal ECU faulty. voltage signal also on A terminal while cranking and check earth terminal C to body no higher than 5 Ohms
power is terminal D 12V
if getting power, earths good, and both signal voltages are going into coil pack, coil pack is faulty.
May 30, 2009 | 2001 Daewoo Lanos
Bought car from car lot need unlock code for 2000 daewoo lanos
Daewoo radio codes
TRY THE CODES BELOW, most common codes used in models during the 1998-2001 model years.
Mar 18, 2009 | 2000 Daewoo Lanos
Radio Communications Logo
435 people viewed this question
Top Radio Communications Experts
Are you a Radio Communication Expert? Answer questions, earn points and help others
