Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Sony hdr-sr11 having similar problem
My Sony HDR-SR11 also is having a similar problem. The SN is 674754. The LCD backlight does turn on and the touch screen doesn't work. Do you have the part number for the flex cable on the LCD screen?
5 Suggested Answers
SOURCE: I have a Sony HDR-SR11 and the time/date stamp is
I believe that you can select the DISP button on the left side of the camera to make the date and time display disappear from the viewscreen on the camera. I do not know if this will remove it from the footage that you will need to download to your PC or DVD. If you have downloaded it already you may need to select the DISP (for display) button and then re-download the movie footage.
Posted on Jun 01, 2009
SOURCE: handycam hdr-sr11: LCD blackout
Did you ever find a solution? I have the same problem.
Posted on Oct 28, 2010
  • 15 Answers
SOURCE: No picture shows up on
If the issue persists even after performing allthe above-mentioned steps, service is required.
Posted on Jan 01, 2011
caroldon
  • 17130 Answers
SOURCE: hdr-sr11 screen gone blank
Possible that the linking cord to the display has come off . This is the flexible cord which moves along with the hinges and in most cases it can TEAR off at the hinges due to wearing .
Now you need to remove the display panel screws and the mount to the camcorder, there are small crews on the sides, remove the LCD panel and check the flexible linking cord.
If this is seen to be damaged order the part from Sony and repalce while threading the strip in the same pattern.
If this fault is not seen then the LCD panel or the drive ( mother board ) is the suspect.
You might need help and support in this case as it involves equipment support.
Thank you for using Fixya.
Posted on Sep 21, 2011
Tip
Mac Sony HDR-SR11 MTS to Avid converter-Convert AVHCD to Avid I have Sony...
I have Sony HDR-SR11 AVCHD HDD camera to shoot family videos and beach videos. However, after I transfer .mts files from Sony HDR-SR11, Avid does not support the AVCHD file. I wonder the best AVCHD workflow into Avid from Sony HDR-SR11 and google for solutions.
I was recommended with Sorenson Squeeze to convert Sony HDR-SR11 MTS to Avid DNxHD codec. However, Sorenson Squeeze does not natively support .mts and the file extension should be changed to .m2ts. The conversion time is much longer than that the original clip. One thing should be mentioned is that the exported DNxHD is loaded quickly to Avid. Sorenson Squeeze also costs quite a lot. I just find a better Mac Sony HDR-SR11 MTS to Avid converter - Aunsoft MTS/M2TS Converter for Mac. The price is dramatically low comparing to Sorenson Squeeze, and the output MOV video works in Avid MC and Xpress Pro.
Here is how I import Sony HDR-SR11 camera videos to Avid Media Composer by converting 1920x1080 MTS to HD MOV.
Step 1. Load Sony HDR-SR11 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR11 MTS to Avid converter on Mac Snow Leopard, and click the "Add" button to load HD .mts videos.
Step 2. Choose AVC MOV for Avid.
Click the "Format" option, and choose Adobe Premiere/Sony Vegas > MOV (AVC)(*.mov), and the Sony MTS to Avid converter will transcode the HD MTS files to MOV for Avid MC, Xpress Pro.
Step 3. Convert Sony HDR-SR11 AVCHD to Avid.
Click the convert button under the preview window, and the Sony MTS to Avid Converter will start converting HDR-SR11 AVCHD MTS to HD MOV for Avid Xpress Pro, or the upgraded Media Composer 5.
As soon as the conversion in finished, you can import Sony HDR-SR11 videos to Avid Media Composer, Avid Xpress Pro for editing. The output HD MOV also works in Final Cut Pro and iMovie, and other non-linear editing software like Adobe Premiere on Mac OS X.
If you are using other Sony AVCHD cameras, you may also face the same problem. Have a look at the Sony HD camcorder page for Sony HDR-XR520, HDR-CX110, DSC-TX7, HDR-TG7 and other models.
on Jul 26, 2010 | Cameras
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I'm doing mine myself. Results to follow, maybe, if I remember to post following the repair.
Jul 15, 2011 | Sony HDR-SR12 HDD Camcorder
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast. With the right external light you could sort of make out what was on the screen by back reflection of what was on the LCD screen.
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I did mine and it works excellently. An $8 cable and about an hour (plus a lot of pictures-as-you-go for reassembly) is all it takes.
Jul 13, 2011 | Sony HDR-SR12 HDD Camcorder
No picture shows up on the screen nor in the view finder when I turn on my Sony camcorder model hdr sr11.thank you.
Jan 01, 2011 | Sony HDR-SR11 Flash Media Camcorder
Handycam hdr-sr11: LCD blackout, images on it are very dark
Dec 08, 2009 | Sony Handycam HDR-SR1 HD Camcorder
Transferring video from camera to intel iMac
Some very useful relevant information here:
http://discussions.apple.com/thread.jspa?threadID=1397298
macs2u
Dec 20, 2008 | Sony HDR-SR11 Flash Media Camcorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
385 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
