Question about Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor
My minn kota riptide 55 stopped working when i turn the handle. i believe its a connection issue. i dismantled the housing around the handle and a little metal washer fell out broke in half and the pieces were warped.how do i replace this part?
  • 76 Answers
Hi!
To start with, here's a schematic:
RT55 Hand Control
Sounds like key# 87 broke....seen it before.
To replace it, remove top cover, then remove the handle portion by removing the 5 screws underneath. There are a few peices in there, so keep close watch. Also be careful of the fine ribbon wire attaching the handle to the control board...it's pretty fragile.
Best of luck!
Mike
Posted on Sep 27, 2009
Testimonial: "thank you very much. This was extremely helpful."
Minn Kota rip tide st 55 very noisy
is the prop shaft bent you may have busted a magnet in the motor dragging now
Jan 20, 2013 | Minn Kota Riptide St Saltwater 55 Bow...
What sizebattery is recommended for a Minn Kota RT40/s riptide motor
Hi, you can get away with a 70 amp hour deep cycle battery but I generally fit a 100 amp hour deep cycle battery. Hope this helps, regards Phil.
Jun 29, 2011 | Minn Kota Riptide 40 Transom Mount...
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
When i plug the motor to the battery nothing happens, until i start moving the conection around. But when let go i stops working.
Check the wires and connectors for continuity, sound like a loose or corroded connection somewhere. Good luck.
Jan 16, 2011 | Minn Kota Riptide St Saltwater 55 Bow...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
How does the pin that holds the yoke come out. I have tried knocking it out with no luck. I also can't seem to find any retainer holding the pin in.
call the 800 number for minn kota on the motor. they will be able to tell you the best way to remove it on that particular motor. they have a very good tech support system at that company.
May 29, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
Online manual needed
I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor Logo
1,110 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
