Question about Andis Outliner II Hair Trimmer
How do i adjust my new outliner 2 blades? - Andis Outliner II Hair Trimmer
    Problem Solver:
  • 17 Answers
Remove the 2 front screws that hold the blade, remove the blade, this has two small screws losen the screws DONOT NOT remove these screws now mve the smaller blade up or down to the hieght you want. when u finish with your adjustment tighten the small screws replace the blade and center the blade in middle.
Posted on Nov 14, 2009
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
My T-outliners are running correctly but they are not cutting even the smallest but of hair and they are pulling. I have adjusted, cleaned, and examined them thoroughly and cant find a problem, they are...
sometimes the blades don't align properly when we put them back together. try to re adjust the blades, they should be 1/16th of inch apart and be level, also makes sure you are oiling the blades before every use, friction causes wear and they won't last as long.
Jun 12, 2011 | Andis T-Outliner Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
I brought the andis speedmaster with the pivotpro trimmer model pmt-1 as was happy to purchase but when I got home and use the pro trimmers they didn't outline the way I expected I thought they would edge...
Some outliners have an adjustable blade set while others are fixed. You will need to remove the blade set and observe if the movable blade is adjustable forward and backward in relation to the stationary blade. If it is adjustable, take caution no to adjust the two blades completely flush. If they are too close they will nip and pinch and can break the skin.
Apr 10, 2011 | Andis Pivot Pro 18174 Hair Trimmer
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
I Want to adjust trimmer so i give a better outline i just bought brand new blades, not sharp enough
what kind of trimmer do u have and what do u want to do fades line up or just trimming i need this info before i can help you model and no#
Adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Sep 05, 2008 | Andis 04603 Hair Trimmer
Andis outliner
Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177
Aug 23, 2008 | Andis Outliner II Hair Trimmer
Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Apr 23, 2008 | Andis 04603 Hair Trimmer
Andis Outliner II Hair Trimmer Logo
650 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
