Question about AOpen ( 91.4ID37.074) (91.4ID37.074) DVD±RW Dual Layer Burner
Installed hp dvd r/rw drive, computer does not recognize hareware
  • 788 Answers
You may want to check your Master/ Slave or CS settings on the back of drive.
If you are useing one cable, IDE cable for both the HD and CD, the Hard Drive sould be set to Master and the secondary drive ( CD ) will be set to slave.
If two cables are used, both should be set to master.
You can F-10 into your BIOS settings to check and see if machine is seeing the connection changes.
Posted on Sep 27, 2009
I have a HP External USB CD/DVD R/RW drive. Stopped working.
First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
(also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
Doesn`t work all the time and makes a whirring noise, do i need to buy a new cd/dvd drive?
Before you beginTo determine if the CD or DVD drive displays on the My Computer screen, follow the steps below.
  1. Turn on the computer and remove any discs from the CD/DVD drive.
  2. In Windows 98 and Me, double-click the My Computer icon on the desktop. In Windows XP, click Start and then My Computer .
  3. A CD/DVD drive icon displays on the My Computer screen when Windows recognizes the drive. If Windows recognizes the drive, find and use a section below that pertains to the CD-writing software with the issue.
  4. If the drive does not display on the My Computer screen, go to the Microsoft support website and search for documents on missing CD DVD drive .
RecordNow by Veritas/HP/Sonic does not recognize the CDRW or DVD+RW driveIf RecordNow does not recognize the CDRW or DVD+RW drive, follow the steps below.
NOTE: Install any updates for the RecordNow engine available on the Sonic support web site (in English). Step 1: Uninstalling RecordNowTo uninstall RecordNow to reset the software and cause it to look for the CDRW or DVD+RW drive again, follow the steps below.
NOTE: The steps below pertain to Windows XP.
  1. Click Start and then Control Panel .
  2. Double-click Add or Remove Programs .
  3. Select Record Now and then click Add/Remove .
  4. Follow the on-screen instructions until the uninstaller finishes.
  5. Select DirectCD and then click Add/Remove .
  6. Follow the on-screen instructions until the uninstaller finishes.
  7. Remove any discs from the drives and restart the computer.
Step 2: Installing RecordNow using Application RecoveryAfter Windows restarts, install the RecordNow software to begin creating CDs.To install the RecordNow software, follow the steps below.
  1. Click Start , All Programs , HP Tools or Compaq Tools , and then Application Recovery .
  2. Click Application Installation and then click Next .
  3. Select HP Record Now or Sonic RecordNow! and then click Install .
  4. The installation automatically installs all files. Follow the on-screen instructions.
  5. Restart the computer after the installation completes.
The HP Record Now or Sonic RecordNow! software should now recognize the CDRW drive. Back to topRoxio (Adaptec's) Easy CD Creator does not detect the CDRW driveEasy CD Creator produces an error message when it is unable to detect the drive, such as: There are currently no supported CD Recorders available...To prevent these errors from occurring, follow the steps below.
NOTE: Windows XP is not compatible with Easy CD Creator 4 and earlier. If the HP Pavilion computer was updated to Windows XP from Windows 98 or Me, use the native CD writing ability in Windows XP or purchase and install CD writing software that is compatible. Step 1: Installing updates for Roxio (Adaptec) Recording Software If the recording software is from Roxio (formerly Adaptec), go to the Roxio software updates page (in English) to obtain any software updates that are available for Easy CD Creator (with or without CD Copier or Direct CD). If Roxio still does not detect the CDRW drive after installing the updates, continue to the next step. Step 2: Changing the CD drive letter back, if it changedUpgrading to Windows 98 or Windows Me can change the drive letter to a different letter and make the drive undetectable to Easy CD Creator. To change the drive letter back to F or another previously designated letter, follow the steps below.
  1. Right-click the My Computer icon on the desktop.
  2. Click Properties . The System Properties window opens.
  3. Click the Device Manager tab.
  4. Click the plus sign next to CD-ROM .
  5. Double-click the CD-ROM name and then click the Settings tab.
  6. Under Reserved drive letters , select M (or the previously assigned letter) from the drop-down list. Be sure that both the Start drive letter and the End drive letter are the same.
  7. Click OK , Close , and then Yes .
  8. Restart the computer. If Easy CD Creator continues to fail to recognize the CDRW drive, continue to the next step.
Step 3: Uninstalling Easy CD CreatorIf the above steps fail to make Easy CD Creator recognize the CDRW, recover Easy CD Creator by uninstalling it. Recovering Easy CD Creator resets the software and causes it to look for the CDRW drive again. Be sure that you have the last recovery disc of your Pavilion recovery disc set before continuing.uninstall Easy CD Creator, Step 4: Installing Easy CD Creator using Application Recovery
Jan 17, 2010 | HP Pavilion dv6000z Notebook
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
When in ''MY COMPUTER'' - CD Drive (E:) was droped into DVD-RW (D:
Try uninstalling the drivers in device manager, shut down, reboot and Windows should find both devices, it might ask for your windows disk to install drivers or search online to install them
Jul 27, 2009 | Computers & Internet
Compaq V2000 - Service Tag V2220US Only recognizes the CD/DVD drive as "CD" Does not see it as a DVD Drive. Listed as: _NEC DVD+-RW ND-6500A in Device Manager.
Try updating your drivers from www.hp.com
If the issue is that it won't play DVD movies only then you probably need to install or re-install the DVD player software that should have come with your computer. If you don't have it anymore, simply download from HP.
Apr 24, 2009 | Computers & Internet
Hd dvd 740with light scrib
Disk's can also fail...but not all...else you have a problem with the drive...you try cleaning the lens...
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | HP dvd740i DVD±RW Dual Layer Burner
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Lg dvd rw installation
Did you install the software first? Sometimes If you jump the gun and install the drive before the software it will not recognize it...
Try updating the driver here:
http://www.downloadtube.com/Drivers/Firmware/LG/
May 17, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
DVD-RW HP H55
This sounds like your jumper setting is not right on the drive. If you have 2 DVD drives installed, make sure 1 is set at master and the other is set at slave.
Apr 07, 2008 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
AOpen ( 91.4ID37.074) (91.4ID37.074) DVD±RW Dual Layer Burner Logo
48 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
