Question about Sewing Machines
I have a Pacesetter NX 400. The automatic needle threader will not thread the needle. I have checked to make sure that the threading process is in order, and when I press the lever down it takes the thread but does not loop it through the eye of the needle. Can you help me? I have misplaced my manual for the machine, and don't know what to do.
  • creativehand Sep 29, 2009
    Thanks for your help! I especially appreciated having the manual in front of me. I have used the needle threader multiple times w/o any problem, I don't know why this happened. Following the instruction manual, I tried 3 times before it finally threaded the needle. On the third try, I pulled the lever down very slowly until it clicked,
    and it worked! Thanks again!
  • 8,197 Answers
Here is a pic on how to thread the needle. Also make sure the threader goes through the needle hole.
Here is the manual.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000154/nx400qug02en.pdf
Here is a quick reference guide.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000155/nx400_qug.pdf
Good luck
Posted on Sep 27, 2009
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Mar 06, 2014 | Brother 50-Stitch Limited Edition Project...
I have a really hard time getting the needle to thread.l I cannot manually pass the thread through the needle eye: the eye is just too tiny; and I cannot even see the hook part of the automatic threader...
I have that machine, and am wondering if your needle has a burr on it, try a new needle, #11 or #80. You may also have no hook in your automatic threader to go throught needle eye. My first automatic threader was defective, no wire to go through the needle to catch the thread. Take a magnifying glass and look when you change your needle and watch when you pull your threader down, do you see a really fine wire come through the needle eye? If, not yours is defective because it has to pull the thread into a little loop for you to pull your thread through it after you release the lever quickly, Mine was a Singer and they sent me a new one right away, Brother will do the same for you, I am sure. Another thing you can do is go to your dealer and have them inspect it, I went to JoAnn fabrics and that is how I learned that I was not crazy, it was the machine,
Apr 20, 2011 | Brother CS-6000
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Auto threader
The parts for any autothreader are necessarily delcate considering the nature of its task. Check (without thread) to make sure the tongue that passes through the eye of the needle isn't bent a tiny bit causing it to strike next to the ****. Have seen this more than once.
Sep 07, 2008 | Brother NX-400
I can't thread the Shark Euro0pro 384 unng the automatic threader
You need to check to see that there is a small hook going through the eye of the needle when you use the threader. A flashlight or bright light will help. So will a magnifying glass. If it isn't, then no amount of trying will help.
If it goes through the eye, you need to see that your thread hooks into it so that the thread can be pulled through.
sewman7
Jun 08, 2008 | Euro-Pro Shark 60 - 384
Threading & Use of Needle Threder
Threading as per image....make sure presser foot is up so top thread will properly engage in tension unit, make sure your thread is inserted in small guide on needle arm too. Your user guide should have a clear graphic of this process which is essentially the same for all machines.
As for the needle threader, once thru the last guide on the needle arm, raise needle to highest position, lower the needle threader so that the tiny hook engages the eye of the needle and place thread horizontally from L to R along the plastic arm so the tiny hook can grab thread, release threader and a small loop will form in needle, pull it clear and you are away !
If the tiny hook has been bent, a little judicious and gentle bending to re-align may be necessary, use a jewellers screwdriver or similar and please be very gentle
Feb 07, 2008 | Janome Jem Gold 660 Sewing Machine
Automatic Needle Threader Doesn't Work All The Time
Needle threaders are generally finicky things. Check to make sure the needle eye is at the correct height for the threader to connect. Gently pull down the threader and wiggle the handwheel slightly to get the needle eye where it needs to be. The threader may have been been bent or slightly rotated so it doesn't connect properly. Also, if you are not aware, a needle threader will usually not work on needles smaller than 80/12 because the eyes are too small.
Admittedly, a needle threader is a very nice function to have. If you find it will not work, there are some things you can do to make manual threading easier. One hint I found that works well is to lick your finger. Swipe it across the back of the needle eye. Then begin with the thread end immediately above the needle eye and gently slide it down to the eye. The needle usually has a tiny groove above the eye that helps guide the thread. The thread tends to jump right through.
Feb 13, 2018 | Necchi 3620 Quilter Mechanical Sewing...
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
