Check the hose for clog up as well as your sump pump. Have your hose unclogged and let it run. Check the sump pump if this is running. And if it is, and still no water goes out. Open the sump, and check the impeller for defect. Impeller is the one that turns around to push the water out. If it is defective, you must replace it to make it run. Once you are done, power it up and start it.
I have a Haier Dehumidifier HDN655E without a manual. I can not find a manual on-line. It runs all...
(More)
I have a Haier Dehumidifier HDN655E without a manual. I can not find a manual on-line. It runs all the time until the bucket is full of water. I thought it was suppose to shut off once the humidity reaches the set leave, whether the bucket was full or not. Also, I would like to to figure out how to set the timer.
