Question about GE Refrigerators
My freezer is now my fridge, and my fridge doesn't cool hardly at all. It runs continually. Frost is built up on back of freezer. Right now it's flashing FF on the front. We cleaned the back with an air compressor, left it unplugged overnight, plugged it back in but it's just not cooling. Both fans are running.It is a TFX27PF
  • GE Master
  • 2,605 Answers
You mentioned the back of freezer was covered with ice. It sounds like a defrost problem. A problem that has been unseen for quite awhile by the sounds of it. In extreme cases you may have to shut it off completely, unpluged and doors open for 24 hrs. or more. Once the unit has defrosted completely, it will cool normally...for a little while. Check the defrost heater and dts (defrost termination switch) and defrost timer or electronic control. If you're not sure, manual defrosting will by you some time (maybe a week) to have a pro look at it for you. Good luck
Posted on Sep 27, 2009
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Whirlpool side by side not cooling
The round object is the compressor. Is it running continuously, or is it clicking on and off every 2 or 3 minutes? There also should be a fan beside compressor. Is it running? Also check Fan in freezer to see if it is running. Is there any frost build up on inside back freezer wall? If fans are working and compressor is running continuously and there is no frost buildup in freezer, then you most likely have a sealed system problem meaning its low on freon or there is a blockage in system.
Oct 31, 2017 | Whirlpool Refrigerators
I have a kenmore model refrigerator freezer model #70982991. It has a top freezer and the mfg. date is 10-00. Right now the freezer part is working but the refrigerator is not. It is used in my unheated...
Lack of freon isn't an issue. Check the internal fan between the freezer and fridge. It is usually located behind the back panel in the freezer. If not there, check upper back of fridge. The internal fan blows the cold air from the freezer to the fridge. When it goes out, the freezer will freeze but the fridge won't cool.
Sep 04, 2011 | Refrigerators
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
Viking refrigerator freezer bottom mount. frost builds up on back wall behind cover panel in freezer. once we self defrost, runs great for 3 weeks and again we defrost with a hair dryer.
Top of Form
Jul 09, 2011 | Refrigerators
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
My fridge runs continuously and the top of the rear inside panel seems to frost up. The fridge is about three years old.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Refrigerators
Freezer is cold but frost building up in the front right portion, also frost on top/ceilngi of freezer and back now too.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 07, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer working fridge not working
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. You will have to remove the back metal wall. Look at the heater. It will be at the bottom of the freezer behind the back wall. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Usually on a circuit board and expensive. Good Luck, Jeff
Jun 01, 2009 | Whirlpool ED2FHGX Side by Side...
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
