Question about Dell F3534 Touchpad
Have a Dell Latitude laptop and the touchpad just stopped working
I Have a Dell Latitude laptop and the touchpad just stopped working suddenly. A USB cordless mouse works just fine. Any suggestions? Thanks!
    Scholar:
  • 67 Answers
It apears to be a hardware problem. You might need a palmrest/touchpad replacement. I would try to reinstall my operating system before anything to check if there is any life sign from the touchpad.
Posted on Oct 04, 2009
    Sergeant:
    Champion:
  • 289 Answers
For some reason most latitudes have this problem, I don't know why but its some problem with both the software and hardware setup.
Posted on Sep 27, 2009
Disable dell e6410 touchpad when mouse is connected
Hi, you can do this by going into the control panel> Mouse> Touchpad settings> disable touchpad when other external usb pointing device is connected.
Nov 13, 2017 | Dell Latitude E6410 Laptop
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
  4. Click on the picture of the touchpad.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
    Click Apply, then click OK.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Aug 31, 2010 | Dell Latitude E5400 Laptop
Have a Latitude D410 running Windows XP Professional. This morning, the touchpad stopped working after coming out of hibernation. If I powerdown and reboot with media base, both the attached mouse and...
try to do system restore it might one of the windows update causes the problem, if fails check system bios compare it from the dell support site if its out dated download bios then flash.
Oct 12, 2009 | Dell Latitude D410 Notebook
The mouse on my dell keyboard has a mind of its own, can i fix or disable it
Go to
http://driverscollection.com/?H=Latitude%20D800&By=Dell
and download and install the driver for the touchpad. If that does not solve your problem then use a USB mouse and forget about having the touchpad.
Aug 27, 2009 | Dell Latitude D800 Notebook
Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Dec 11, 2008 | Computers & Internet
Dell latitude C840
try using the usb mouse then go into control panel>system>hardware>device manager. Click on the +sign next to touch pad or pointing devices and right click on touchpad, then click on uninstall. Reboot the computer, unplug the usb mouse and the touchpad should be picked up as new hardware and be re-installed.
Dec 08, 2008 | Dell Latitude C840 Notebook
Deel laptop inspiron e1505
If you have a spare USB mouse, you might try plugging it in to the laptop. Then go to your control panel. Go to your mouse settings, and be sure that your settings are correct for the touchpad.
Is this a new (to you) computer, or have you had this a while, and then it happened all of a sudden?
When you plug in the USB mouse, it may take a few seconds to recognize the mouse.
Dec 31, 2007 | Dell Latitude CPX Notebook
Computers & Internet Logo
1,087 people viewed this question
Alun Cox
