Ut of the blue a large black box shows up in the middle of the screen. It is a perfect rectangle and takes up about 80% of the screen. When you move the volume button or change a channel it goes away but comes right back. Used to be able to get to HD channels and it would not happen, now it happens on all channels regardless of the input, DVD, Cable box, direct cable.
  • arnoldband Sep 27, 2009
    thank you it worked!!!!
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
This is simple, please turn the close captions to off using the Tv remote.
and the cable remote if needed
Also for future make sure if you use the CC closed captions , set the setting to CC1 never text mode.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Posted on Sep 27, 2009
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Trouble viewing DVDs
I signed up for the "chat" and the problem was solved very quickly. Thank you - great service!
Oct 07, 2008 | Televison & Video
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
Black screen
I have a Sharp Tv that had the same problem with a large brownish or black square right in the middle of the screen. It only left about an inch around the edges that you
could see the picture moving in behind the big black block or square.I have DISH sat-elite and the book recomending that I check and see if the "caption settings" were on
or off. They were on. I turned the caption settings off and the large square diappeared.
Nov 18, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
Aug 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
