Question about Dell Computers & Internet
The screen stays on for only 2 seconds and then goes black. I push the button on and it will come on again for 2 seconds for several tries. Pretty soon it won't come on at all but you can see the button turn on and off on its own with a faint flash on the screen. After awhile "Dell" appears briefly on the screen and it stops flashing on its own. I can then turn the screen on and off again for awhile with the button and then the process starts all over.
Most likely the back light is problem.
If you see the whole screen initially, the CCFLs are ok.
Solution 1. Replace the power board, if you can get a cheap one.
Solution 2. ** Warning ** This method defeats the protection circuitry, not safe. watch closely (not only on the screen) while the monitor is plugged to the power.
On the back (solder side) of the power board , there is a 16 pin IC, OZ9938. Solder a 50K ohm resistor between pin 16 and pin 3.
You may see the screen, but not be able to adjust the brightness, which has been broken at the first place, causing the whole episode.
Posted on Nov 20, 2009
  • Edward Collins
    Edward Collins Feb 23, 2016
    I got a dell monitor s2009wb had this problem, I installed the 50 ohm resistor, On pins 3 and 16 on the 16 pin chip, It works great, Thanks a bunch, Ed
  • Dell Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 27, 2009
My kindle fire will not stay turned on! When i hit the on button it seems like its going to go but then the screen goes blank!
Did you try with power plug on ? If ok, the battery is gone. If not, try restarting (keep POWER button pressed several seconds and after few seconds press once). If you see the logo on screen and then black, look in a very dark room to adjust luminosity setting.
Sep 10, 2017 | Tablets & eReaders
Coby tftv2224 hard to turn on takes several tries
Sounds like bad power supply capacitors, simply fix if you have electronics repair skills.
May 20, 2012 | Coby TFTV2224 22 in. LCD TV
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Jul 06, 2009 | Computers & Internet
My alpine car cd player wont stay on....
There is a Title button (above the volume knob). Push it and hold it for 2 or 3 seconds. It was either that, or push and hold the 'Function" button on the glide bar... pretty sure it was the title button though. It will come back on.
Apr 07, 2009 | Alpine CDA-9855 CD, WMA, MP3 Player
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Computers & Internet Logo
1,133 people viewed this question
Alun Cox
