Question about GE Refrigerators
GTS22KBMBRWW GE refrigerator; the compresser does not come on, no indicator light for freezer compartment. Indicator light on for the bottom section.
  • GE Master
  • 1,606 Answers
Due to the compressor not coming on , this is an indication of a bad main control board . Part number WR55X10942 . Occasionally , if you remove the board ( behind the 8"X10" panel , on the back of the refrig ) , and look on the soldered side , just behind the small black boxes , you'll see a spot , which has become unsoldered . You can re-solder this spot , and the compressor will run . If you do not see the spot , then the module is bad , and the control board will have to be replaced .
Posted on Sep 27, 2009
    Problem Solver:
  • 11 Answers
If you (or someone you know is competent at soldering, you may be able to fix this without a pro (nor replacement part).
At the rear of the fridge is a metal panel at top left behind which is the motherboard. If the problem is intermittent - e.g., slamming the door yields a loud 'click' and you hear the compressor start, chances are great that the problem is a bad solder joint on the relay that switches between defrost and compressor modes. (It seems to default to defrost mode.)
Unplug the fridge!
Remove the metal panel. (1/4" hex wrench or socket set req'd.)
Gently and carefully (wiggle and) remove all molex connectors from the circuit board. (There'll be 5 or more, possibly depending upon how many extra features your fridge model has.)
Use a suitable tool - needle nose pliers or strong tweezers - to squeeze the plastic stand-offs with which the board is mounted to the fridge.
Remove the board from the fridge. (Note: it may be easier to remove the connectors at the right of the board AFTER the board is lifted off the stand-offs.)
Look at the solder-side of the board.
You'll almost certainly see charring around a particular solder joint that belongs to the large, sort of T-shaped relay (black box) on the board.
Clean up the carbon with alcohol.
Scrape away some of the (green) coating on the copper trace around the pin that comes throught the board from the relay. (This will entail removing some of the acrylic clear coat with which the board has been sealed.)
Resolder the joint.
Clean up any flux residue.
Reinstall the board - right-hand connectors first, if necessary (i.e., before mounting the board on the stand-offs).
Replace the metal panel.
Plug the fridge in.
Listen to that relaxing buzz of relief...(and $100-$200 savings).
CAUTIONS: 1) Make sure you NOTE and/or remember which connector goes where on the board BEFORE you remove it.
Posted on Jan 08, 2011
Hi,my GE refrigerator have alot of ice in the frezer comparment hoy can i fix? Refrigetor side not cold. Thanks
First off,
Ice build-up in the freezer compartment is an indicator that the defrost system is not working properly.
The defrost system is composed of the defrost heater and the defrost thermostat. If one of them is not working, ice will build up in the freezer compartment.
You need to do a continuity test on the defrost heater and if it is good, very likely the culprit is the defrost thermostat. Just replace the thermostat
Aug 02, 2017 | GE Refrigerators
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Temperature is reads 73 on freezer and 34 on refrigerator But... inside all are warm Help
It may be vice versa.
You need to check and make sure that the freezer section is 34 degree. The refrigerator compartment depends on the freezer in order to maintain a temperature suitable for food storage. If it is the case, you defrost heater and thermostat may be defective.
Dec 10, 2010 | GE Profile Stainless Bottom-Freezer...
The top of the freezer compartment does not freeze ice, but the bottom does. The top of the refrigerator compartment is not cold, but the bottom drawers are freezing.
It sounds like the fan in the freezer is not working , letting the cold air sink , and going into the refrig section from the bottom . Replaceing just the main control board may get the fan going again , however , replaceing both ( possible shorted fan motor will cause the new board to malfunction again ) would be the better suggestion .
Mar 04, 2010 | GE GSS22KGPBB / GSS22KGPWW / GSS22KGPCC...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Repair
Defrost system problem will be indicated by frost (snow) on back wall or cooling coil is located in the freezer compartment. Check freezer control setting. If it is set to cold for the freezer it reduces cold air to the refrigerator section.
Mar 26, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Refrigerators Logo
343 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
