Question about Apple iPod touch
Invalid Argument error in iTunes and App Store of iPod Touch 3.1
I have this error too! Hope Apple can solve this! I cannot connect to the internet with Safari too! May I must downgrade my software? I've wasted 600 yen for that ****!
Do the following... On your Touch go to Settings -> General -> Reset -> Reset Network Settings..... When it starts again got to Settings -> About and check to see if your Wi-Fi Address has been Reset. Hope that helps
Posted on Nov 03, 2009
  • mikenappy Dec 03, 2010
    This worked well. The only thing is, when you reset your network settings, you will be asked to enter your WiFi password. When you enter your 26 digit WEP key you will be able to connect to the internet again.
I had the same problem where the "invalid argument" would pop up even though i thought the wifi was connected. None of these solutions worked so I was just playing around to see if anything would work. What finally did it for me was clicking on "other" when it asks what network you would like to join. I then typed in the name of my network and copied the "Wep key" off the back of my server. After joining my network this way it finally worked. Good luck
Posted on Jan 27, 2010
  • Ricky Spano Oct 23, 2011
    thanks so much it worked!! the luck did work very well!
WOOH! ok ok ok, so! iv spent weeks looking through stuff like this, i thought the wifi on my itouch was bad.
I have a 2wire router and it says i was logged in but still the wifi didnt work
TURNS OUT!
i used my "system password" and although it logged on it wouldnt work. but i tried the "wireless network key" (all written by the barcode on the router) and it worked perfectly.. sooo happy =)
Posted on Apr 21, 2010
  • kristengstev Sep 14, 2010
    This worked for me! Thought I was connected to the internet because I had a signal....but still getting "invalid arguement". Went into settings and changed my 2wire password to the key on the bottom of my modem....and got on the internet. Thank you!
    For anyone wondering, it is not the SN number, but the next one down.
This is ridiculous. whenever i try to open the app store it says 'invalid argument' and when i try to open safari the screen dims and it says connecting but it wont connect. Apple come on, please fix this. its been happening too long and ive stopped using my ipod. your going to lose a lot of money and customers if you dont fix this problem. dose this mean your ipad will have the same problem? looking forward to that...
Posted on Feb 27, 2010
I just got mine for christmas yesterday,
and i cannot get mine to work
app store and itunes says invalid argument
but now my apps wont load either
they show up and then disspear again
Posted on Dec 26, 2009
    Sergeant:
    Champion:
  • 289 Answers
Update itunes and update the firmware on your ipod. and no you didn't waste your precious yen... (more like $6 here) also the argument error is actually some problem with the software you downloaded...
Posted on Sep 27, 2009
I tried everything on here and than restarted ipod and my wireless router, and now it is working!
Posted on Feb 06, 2010
Ok, now there are a lot of reasons concerning this problem, from manual input to system bugs, I'm sure that when you read this, you would have tried (and failed with)a LOTof methods from the above solutions and etc. so, now im gona say an alternative method. When the restore network ****, restore the entire ipodcrap, renew lease ****, deleting apps **** (and more) all else fails, its maybe ur WEP keyword that is wrong. what i mean is, you should input the hex password instead of ur usual wep router password or whatever it is. To PC users, you can know ur hex password through ur working (and connected to the router) computer. Just go to the connections page in ur (desktop manager i think?) and then look at the Properties tab of ur connect router signal. There should be yet another called "security" tab in it somewhere. Selected that and another window should pop up ( I think) Look at the network security key and tick the "Show characters" in ur admin mode, then u should see your hex password . type it in ur ipod connection password and pray for the best.
This worked for me (My pc is a win 7) (3rd gen ipod 3.1.3) goodluck
Posted on May 21, 2010
  • Mikey G 1253 Dec 15, 2010
    OK the reason being for all the messed up itunes or app store on any ipod touch device first generation etc... is either because your IP address has been mixed up or for other purposes. if the first numbers in your IP address are 169 then that could be the problem. In order to check if this is your problem simply go into settings and click wifi then under wifi click the arrow that is at the end of your connected network and here it will show your ip address then only check if the first three numbers are 169 if so then click the forget this network tab and after doing so connect to your network again and your IP address should be restored and running smoothly again. If none of this helped you then simply just turn your ipod off and back on hopefully it works this way to but highly doubtful because of the slim chance of it working well thanks for reading this guide and hope your buying more stuff from either the app store or Itunes have a good day. ---Mike Garcia-------
I had this problem but i have figured out how to fix it. Go into settings, the tap on wifi, then double tap the blue arrow on your chosen network. Now in the IP adress field you need to change it so it begins with 192 eg.192.134.1.6. Now scroll down and tap renew lease and that should fix it.
Posted on Jan 01, 2010
This should work. Open up iTunes library & connect the USB to the computer. Hold don the power switch & silde the red arrow to turn off the iPod. Hold down the Home button while attaching the USB to the iPod. Keep holding it down until you see on the iPod screen a USB pointing towards iTunes. Now click to restore the iPod on iTunes...Worked for me
Posted on Feb 17, 2010
OHHHH... So simple. I performed each one of the "solutions". It came down to unplugging my wireless router, letting it reset, plugged it back in... Whammooo. All is good. Try this simple method first. Save yourself a load of frustration.
Posted on May 30, 2010
I've tried everything everyone has said above
e.g Settings>General>Reset>Network Settings....
but it just doesnt seem to work. Any other soloutions??????
Posted on Jan 24, 2010
Nothing has worked. it shows i have wifi conection with the 3 blue bars at the top but when i open safari it says "safari cannot open the page because it is not connected to the internet" and it IS connected to the internet!! there is a check next to the wifi network. but it also keeps on disapearing
Posted on Feb 26, 2010
Hey i have tryed all the sugested abovee and none seem to work :(
would like a solution that actualy does work if anyone out there has one :/
i have forgot the network and tryed again i have reset the settings i have reset my router and nothing is happening i'm still getting invalid argument PLEASE HELP!! :(
Posted on Jan 26, 2010
This help and its true i updated my ipod last night and i got pissed that i couldnt open app store or youtube etc. so today i turned off mi router and modem at the same time and connected it and it work
Posted on Mar 21, 2010
  • 4 Answers
I belive its now happening with ipod 3.1.3 :s
Posted on Feb 16, 2010
How do you change your ip adress mine starts with 169
Posted on Jan 10, 2010
I just turned mine off then back on again
Posted on Jan 30, 2010
  • cans352 Jan 30, 2010
    i just turned my ipod off then on again hope it helps
    p.s it's easier then everyone elses
Settings> general >reset> reset network settings then switch off your ipod after it has reset and it should work.
Posted on Jan 19, 2010
Im having the same issue and nothing im doing to try and fix it is working. im about to give up and take it back ware i got it.
Posted on Dec 24, 2009
None of the above works pls help
Posted on Feb 09, 2010
I actually fixed this problem by erasing one of my apps on my ipod. IT SERIOUSLY WORKED FOR ME!!!
Posted on Jan 02, 2010
It helped me thanks yiorgos41
Posted on Nov 11, 2009
None of these worked iv reset my network settings restored my ipod turned it on and off nothing and im getting the urge to go return it and get my money back its way to frustrating come on apple jeeze
Posted on Feb 20, 2010
  • 3 Answers
I did the renew lease solution and it worked .....
Posted on Mar 05, 2010
None of the solutions above helped. My setup is a combo modem/router and a separate wireless access point plugged into the router. The access point was 8-10 years old and started to fail, so I bought a new one. Now my problems are solved. For those of you who can update the firmware on you access points or replace it, this may solve your problem.
Posted on Apr 27, 2010
Thanks to everyone..3 grandchildren who couldn't connect..rebooted the router..and synched with itouch and worked like charm..sometimes it happens with my computer at home..and rebooting always does the trick
Posted on Sep 04, 2010
Paid £229 for a load of ***t no wonder the copy companies do well. apple a multi million $ company makes things so hard
Posted on May 15, 2010
Every single thing doesn't work its 2013 and it still doesn't work I've had enough i just wanted to play some games on my old ipod and it's annoying
Posted on May 06, 2013
doesn't work for iPod touch still invalid argument..... still trying find a solution on this problem....
hope that ipad doesn't have this kind of problems....
Posted on Jun 16, 2010
This all happened to me and i tried resetting the networks etc but then i connect my ipod to a different computer, rebooted the ipod and set it up again as a new ipod and then it all worked :)
Posted on Jun 03, 2010
Check your internet passcode really good cuz i kept fliping my numbers and i updated my ipod after i had just downgraded it and went through this whole mess to find out i was fliping the passcode 244 to 422 i had it backwards
Posted on Apr 22, 2010
Plug it into your computer and at the sumary screen hit restore on itunes, back up your files. and then restart it. otherwise call 1 800 MY APPLE
Posted on Mar 23, 2010
My i pod touch says invalid argument when i go the app store?why does it do that
this its a problem with the internet connection
check if you can browse the internet, if not review the internet connection settings
Apr 02, 2011 | Apple iPod touch
Invalid argument
FIRST OF ALL GO TO SAFARI AND TRY TO VISIT any other website BESIDE google.com
if it connects then check the networks firewall settings.
if it doesn't then this is because of your network connection.
Mar 07, 2010 | Apple iPod touch
When i go on to the app store,youtube,safari or itunes store it keeps coming up "Invalid argument"and i have only had it 3 months
Try updating to the new software, could be a bug. If not then please contact Apple.com
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Apple iPod touch
How do you connect to app store when your ipod touch says cannot connect to app store invalid argument
Update the ipod software to 3.1.2 to address wi/fi problems, but dont update to the latest version 3.1.3 because the sneaky bastards at Apple used 3.1.3 to undo the jailbreak from Black Rain and Cydia. Theres no big improvement between 3.1.2 and 3.1.3 anyways.
Now make sure your ipod is fully charged and touch settings, wi/fi, slide the wi/fi to on, choose the same wi/fi you use to connect with your computer, and input the same user name and password, push the home button at the bottom of the ipod, then touch on Safari and the internet should be there for you.
Cheers old chap.
Mar 01, 2010 | Apple iPod touch
How do I fix ipod touch invalid argument problem
no i have the same problem and i have had my ipod for 3 weeks now and have still had no sucsess on fixing that and it is realy peing me off...
Jan 03, 2010 | Apple iPod touch
I can connect to my NETGEAR router okay with my iPod touch 2nd generation, but whenever i try to connect to iTunes or the App store, it says invalid argument, how do i fix this
On your Touch go to Settings -> General -> Reset -> Reset Network Settings. When it starts again go to Settings -> About and check to see if your Wi-Fi Address has been Reset.
Dec 29, 2009 | Apple iPod touch
Cannot connect to itunes store or internet - invalid argument
get the cord to the computer/ipod plug it in then there you go
Dec 28, 2009 | Apple iPod touch
It says invalid argument on all internet
when i go on the app store it say's invalid agument and i dont know what that means?
Dec 26, 2009 | Apple iPod touch
Invalid argument on itunes and app store from ipod touch
do the followings
settings>>wifi>>you will see a blue arrow button next to the connection press that.
if you see the 1st 4 lines full with some number and writings then it is ok or else scroll down and press renew lease or/and try to connect using another network.
let me know the result.
check this onehttp://www.fixya.com/support/t4259513-itouch_wont_let_me_connect_internet
Dec 04, 2009 | Apple iPod touch
My i-pod touch (8Gb) can't connect to internet
This worked for me: Went into SETTINGS > Wi-Fi > Selected my Network (which my iPod said I was already connected to) > Selected "Forget this Network" (which disconnects you from your network) > Re-selected my network and under password, I entered the 'Security Key' from my Verizon FIOS Tech Wizard info and the device accessed the app store successfully.
Sep 20, 2009 | Apple iPod touch
Apple iPod touch Logo
48,892 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
