Question about Ovens
St George double wall oven DEO 7A,(approx 12 years old) top oven will not heat up to cooking temperature. Everything works fine, fan, light oven turns on, but will only heat to about 60-90 degrees approx
5 Suggested Answers
  • 512 Answers
SOURCE: St George Oven Door - Glass Broken
http://www.sga.com.au/User-Manuals/default.aspx
Anyway that will get you to the right people.
Posted on Sep 20, 2009
SOURCE: St George DEO 7 oven temperature not going past 170
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Posted on Dec 29, 2009
  • 106 Answers
SOURCE: DEO-6 top oven doesn't heat when fan oven is used
check wiring to cavity air pressure switch terminals eg the two wires should be connected to common(c) and Normally open (NO)
Posted on Jun 14, 2010
tbreeze47
  • 3083 Answers
SOURCE: it is a relay board
Some relay contacts can be replaced, and often one can clean them with emory cloth, and restore the operation. If the coil is open, it has to be replaced.
The only place online I could find that has a variety of parts is here:
http://www.stoveconnection.com.au/stgeorge.html
If you have any literature that came with the unit, refer to a support number, if possible.
Otherwise, you might advertise on Craigslist, and hope some appliance shop has it in stock, and surfs the internet.
That's all I could come up with, but hope it helps.
Posted on Jan 19, 2011
May 16, 2010 | Ovens
The top oven of our double oven will not heat up. However the fan still comes on...could this have to do with the elements or is it something else?
Hi.
Did you notice whether the mains circuit breaker tripped while you were cooking last?
Howvever if your temperature light comes on and also the fan then the most likely cause is a fan element.
Should you need any help with obtaining a replacement part please email me on: aardvark.repairs@btinternet.com
regards
Aardvark repairs
Nov 17, 2009 | Frigidaire 27" Built-In Double Electric...
Merrillie,
Simon
Sep 06, 2009 | Ovens
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Ovens Logo
109 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
