Question about Canon PIXMA MP960 All-In-One InkJet Printer
Printer lost power last night - won't power back on. Not exactly sure what happened - no power surge or anything like that. Printed a page and the printer turned off, won't turn back on.
    Sergeant:
    Champion:
  • 289 Answers
Maybe the transformer blew... high chance of it too... (unless of course theres a fuse hidden in there somewhere...)
Posted on Sep 27, 2009
Desktop won't make a sound when I turn it on
Check to make sure the power switch on your surge protector hasn't been reset - also check the connection at the back of the computer -
Jan 15, 2013 | Systemax Venture PC Desktop
Help please - last time I tried to use printer, 'on' light stayed solid green and nothing would work, however after 45mins approx it suddenly returned to normal and printed fine. Now sx115 is...
This could be due to various reasons.
1. Make sure that printer is connected directly to a wall outlet and not to any surge protector.
2.We can perform a cold reset or restore the printer to factory defaults. If the printer is connected to a network then make sure that we make a note of the network settings since the settings will not be the same after performing the reset.
Sep 10, 2011 | Epson Printer Accessory
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
We had a power out for a few seconds and the bl 2170w only comes on for less that a second. If I hold the Go button when it is turned on the 3 indicator lights stay on. If I let go and repress the Go...
Unplug the power to the printer before the power comes back on to avoid any damage due to surges when the power is back. After the router is back on and working. Plug your printer back. Then press the blue button for 10 seconds so that the setup page is printed. Your printer is now back on.
Sep 30, 2010 | Brother HL-2170W Laser Printer
107.08 service printhead error message appears on screen - only installed printer 2 days ago.
Take the back panel off and reseat the ribbon cable in the top middle of the system board..Just got off the phone with tech support and it worked...
Nov 19, 2009 | Lexmark C543dn 26B0000 Workgroup Up to 21...
My flat screen lg tv has lost its channels,says its not programed...help
i was watching tv last night on my lg,and it went off and said no signal?so i went to retune and now it says not programmed i cant get my dtv channels back
Aug 20, 2009 | LG 42PG20 42 in. Plasma HDTV
Powered-off printer makes noises
Have you tried plugging it in without surge protector? Also, open front cover and make sure there isn't another power switch in there. Some Lexmark's have a push power button on control panel....but have an actual physical power switch on the inside of the front cover. So it may not be fully powered off. I am a Lexmark Tech, I've seen this on a few models.
Mar 12, 2017 | Lexmark X5470 All-In-One InkJet Printer
My HP 1100 won't print after power outage during printing
Not worth it to fix. You can find 1100's on ebay for $30.
Mar 02, 2009 | HP LaserJet 1100 Printer
Nothing happening
Are you sure it was a surge protector and not just a power strip? They look the same. Just a thought =)
Jan 15, 2007 | Cyberhome DVR 1600 DVD Recorder
Canon PIXMA MP960 All-In-One InkJet Printer Logo
230 people viewed this question
old marine
old marine
