Question about Goodman CLQ36AR49 Air Conditioner
Goodman outside unit not kicking on after power outage
  • 358 Answers
If the outside fan works ,try to put a booster cap. in parallel with the capacitor , but if nothing works check the outside power supply box (or discennect) to see if a fuse is blown.
Posted on Sep 27, 2009
Goodman compressor not running after power outage
no reset replace capacitors. check terminals on compressor to see if a wire burned off
Jul 31, 2012 | Goodman Heating & Cooling
Where would the reset switch be located on a goodman ac unit
There shouldn't be a reset switch. The only units I've ever seen or heard of having a reset switch were old Rheem condenser, they had a high pressure switch that you could reset by pressing a red plastic button, but even Rheems no longer have them and I've never heard of Goodman using them.
What problem are you having with your A/C system? And why are you looking for a reset for it? Please repost your question and give us a bit more info so that we may help you with your probelm.
Jun 14, 2011 | Goodman CKL36AR36 Air Conditioner
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
I have a Goodman ckl49-1 airconditiong unit that
Check for burned wires at the outside unit and if the fan doesn't work could be the capacitor or the fan motor itself , i would try replacing the capacitor first is no more than $25.
Aug 27, 2009 | Heating & Cooling
I have a Goodman CK36-1a outside unit. It will not kick on.
If you have power to the unit and the contactor is pulling in ( low voltage side ) and neither compressor nor the fan comes on it could be 1 of 2 problems first check the wiring a mouse may have chewed through one of them, or 2nd your capactor is bad.
Ron
Cozy cool home comforts
Jul 05, 2009 | Heating & Cooling
I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Jul 03, 2009 | Goodman CLJ36AR42 Air Conditioner
The outside unit runs but the inside doesn't blow
COUL BE A FAULTY BLOWER RELAY BOARD OR THE MOTOR COULD BE GETTING HOT AND SHUTTING OFF ON OVERLOAD. CALL A CONTRACTOR
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Goodman CK36-18: Outside fan kicks on, but
Sounds like a bad capacitor. They can be bad and the fan will still run. Turn off power and check for burnt wires on the top of the contactor going to the capacitor or on the top of the capacitor.. Check terminals on the compressor also. When capacitors go bad they are slightly swollen. They can also look good and be bad . Could be compressor but start with capacitir and wires. IWork on a lot goodman units. Most of the time it is the cap.
Jun 03, 2009 | Heating & Cooling
My goodman cple18-1c model central AC unit blowing hot air
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
Sep 13, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
211 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
