Pioneer SD-533HD5 53 in. Rear Projection HDTV Television
Problem for Pioneer SD-533HD5 53 in. Rear Projection HDTV Television
I have a pioneersd-533hd5 there is a purple shadow
By cedgell660 on Sep 27, 2009
i have a pioneersd-533hd5 there is a purple shadow under display letters and sems out of focus
Solution #1
posted on Sep 27, 2009
Somewhat Helpful)
Ecollier2012
Rank: Guru
Rating: 93%, 550 votes
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Was this helpful?
Yes
No
Popular Solutions for Pioneer SD-533HD5 53 in. Rear
Questions and Unsolved Problems for Pioneer SD-533HD5 53 in. Rear
Do you recommend Pioneer SD-533HD5 53 in. Rear Projection HDTV Television?
Answer
Answer
hi, my tv is cutting off on its own and it wont turn back on unless i reset the main power
Answer
when the tv is turned on, the screen is dark, with a green tint. Will eventually correct itself.
Answer
picture disappears while TV is on. When TV is turned off for a while, it turns back on, but only... (More)
Answer
my protective screen is cracked on my pioneer sd533hd how can i remove it I need to know how to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer SD-533HD5 53 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
