Question about RCA P52926 52" Rear Projection Television
  • Anonymous Dec 27, 2007
    sometime I can not start the tv with the remote
  • 4,402 Answers
First replace these caps C4102, C4118, C4108 and if that doesn't fix it replace High voltage splitter.
Posted on Jan 09, 2008
My tv will not come on . It blinks 5 times then 4 times . Any ideas ?
possible cause sometimes busted capacitor, better to send it to repair shop to replace the damage parts.
Just a suggestion thanks hope it helps.
Sep 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
RCA 52" rear projection tv
This could literally be anything. I have a tip at which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
May 23, 2011 | RCA P52920BL 52" Rear Projection...
Tv won turn on
This could be caused by a bad HV block. I would not take on replacing unless you know your way around HV circuits on Projection TV's. I would call a repair facility to give you a estimate to repair.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
Rca mm52110 rear projection tv with issues
Will power up, but won't have a picture. What could cause this?
Sep 16, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
My rca projection tv some times the channels will change by them selves and just run and my speakers dont work anymore
This happening because you have loose connections in the tuner. Re solder and you will see changes. About sound, did you try to move switch repeatedly ? ( back on) sometimes corrosion inside do problems contact. I hope this work for you Am here any time .. Thank you. Yambo
Aug 05, 2008 | RCA P52926 52" Rear Projection Television
RCA P61927 61 in. Rear Projection Television
get a tv repairman out to make sure of the problem, it might be xomething simpler he can fix but it sounds like the convergence board is out
Jun 21, 2008 | RCA P61927 61" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
