Question about T-Mobile Sidekick ID Cellular Phone
Sidekick id with charger light on and no lightning bolt on phone
Sidekick id charger light is on but lightning bolt is not on phone and the bars are not moving.
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
Battery
Nomad182-
So did you buy it new? If so take it back. If not, then you got a used one that has a bad charginfgport. The sidekick 3 is notorioius for it and the sidekick ID has an issue with it as well. The orange light comes on but the connection that charges the battery itself is broken. Check out www.cellulardr.com. They charge about 75 dollars for the repair or you can do a workaround that charges the battery seperate form the phone.
The following link shows it for the sidekick 3 but the sidekick 3 and sidekick ID batteries are the same.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
I would also recommend a second battey so you can have one charging at all times. They runa bout 5 dollars on ebay.
Nov 11, 2008 | T-Mobile Sidekick ID Cellular Phone
SIDEKICK ID
i wanna use my side kick id in the bahamas with a gsm sim card but it won't unlock??
Oct 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Wont turn on
Sometimes you have to give it a half hour or so of innitial charge
Sep 09, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick wont turn on
If you can, try a friends battery, either from a sidekick ID or sidekick 3. The Sidekick ID seems to be having the same issue as the sidekick 3 whefre the charging port goes bad. The best worka round for that is to get a charginfg cradel that has a spare battery slot.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick / Hiptop 2 won't take charge
The battery might be an issue. Sometimes with lithium Ion batteries, tehy just act retarded and need to be jump started from the dead. Buy a battery from any vendor and test it out. If it doesnt work you can always return it.
Sep 17, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
