My lg rear projection tv stopd working at onece and there is no light in the indicators .its model no is mw-60sz12. can it happn becouse of lamp
  • 832 Answers
1. Unplug the cord & check if there is power at the
outlet.
2. Check for a busted fuse/or tripped off circuit
breaker at the main power panel pf your house.
3. Check for the busted fuse inside the case of your
projection TV. This is just near where your power
cable of your TV is connected.
4. When you are done, plug back your cord to the
power outlet, and put the power on.
This should correct your problem. Send us your email and keep us informed.
Posted on Sep 27, 2009
I have an LG Rear projection TV Model No. MW-60SZ12, it has patches of blue tinge through the bottom of the screen, i have replaced the globe and the picture has improved but i still have these blue...
your optic engine is stuffed! the blue ,green & red optics are glued into place instead of screwed.after time this glue fails and the colours fade onto the screen. very common problem with this model.
Jul 20, 2010 | LG Televison & Video
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
The lg tv clear middle and blue around the outside it is an lg dlp mw-60sz12
Verificar a filtro do lcd azul, antes da luz atingir o lcd. Há uma película prateada que solta desse filtro e a imagem passa a ficar azulada. Lg não fornece o filtro separadamente do conjunto óptico.
Oct 17, 2009 | Televison & Video
RESET LAMP HOURS
press the menu button on the front panel
while holding button on panel press and hold the menu button on the remote control
service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
press ok on remote
and now lamp hour is reset
Jul 31, 2009 | Televison & Video
I cannot find my tv ariel hole to plug my ariel in
It's not a TV but a monitor. You need an external tuner such as a satellite or freeview (in the UK) box to drive it
Jun 29, 2009 | LG Televison & Video
Blue screen lg rear projection tv mw-60sz12
Lcd rear pro MW-60Z12 turn on but it on screen says Video no signal
Jun 09, 2009 | Sony KDF-E42A10 42 in. LCD Television
Problem with LG LCD TV, model MW-60SZ12. there is a blue shadow that starts from the right corner and goes down to the bottem of the screen. it stays on all the time even on a black screen (not off)....
Verificar o filtro do lcd azul dentro do bloco óptico, antes da luz atingir o lcd. Há uma película prateada que solta desse filtro e a imagem passa a ficar azulada ou manchada. Lg não fornece o filtro separadamente do conjunto óptico. Tem que trocar o conjunto óptico completo cód.: 3141VSN200B.
Sep 02, 2008 | Televison & Video
LG LCD Rear projection TV with a blue flare on the screen
Verificar o filtro do lcd azul dentro do bloco óptico, antes da luz atingir o lcd. Há uma película prateada que solta desse filtro e a imagem passa a ficar azulada ou manchada. A LG não fornece o filtro separadamente do conjunto óptico. Tem que trocar o conjunto óptico completo cód.: 3141VSN200B.
Jan 01, 2008 | Televison & Video
Mw-60sz12 parts
Hi there.
I am a service tech.
After reading about the this particular l.g. set i decided to llok into the optic engine and
have found that the blue polarizing lense is crook.
Believe it or not but the set will work fine if you remove this lense, alternatively if you remove the lense
and want to replace it. Go to ebay and type in hoya polarizing lense. Buy the 72 mm circular lense.
Then cut it to size and replace it .
Has fixed many of my customers sets.
Hope this helps.
Jan 01, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
