Question about Samsung Exclaim M550 Cell Phone
My phone will not dail out r send a text - Samsung Exclaim M550 Cell Phone
I am using the PE 16 & suddenly I get a comm. error when I try sending faxes, both using the automatic dialling or dialling manually - I tried unplugging from the elect. & the phone line &...
comm error could mean numerous things is the phone line cord your using new? do you hear it dailing or a dail tone? are you on dsl as far is Internet these use filters that can mess with communication.Does it use standard dailup to send faxes
Jul 04, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
My tap screen doesnt and i cant text or dail numbers
Could be a bad digitizer.
Have you tried a hard reset on the phone by pulling the battery while the phone is on, then waiting a few seconds?
Jun 11, 2011 | T-Mobile My Touch Cell Phone
It will not receive text messages but i can send then i can also send/receive calls
hi connerlist rake the battery out. then put the battery back in and next dail *228 and option 1 then
it should start sending the txt messages.
Apr 25, 2011 | LG enV3 VX9200 Cell Phone
My phone will not ring or text message, when I call it, it goes straight to my voicemail.
hi kellyj01647 dail *73 on your phone. this shoulf help. then have someone call you to make sutr you are getting the callls
Mar 09, 2011 | LG VX6100 Cell Phone
I can't open youtube video and it says about setting wifi
HI lee 1181 your phone is set to wifi, go into connections and change the phone to mobile. next you will need to make sure that the broadband is dailing 7777. you can do a *228 on your phone and next send. OPTIONS 2 THIS WILL UPDATE the phone for you. if you can't get the phone to do anyof this dail 611 from your phone for help. hope this helps
Feb 28, 2011 | Samsung SGH-i900 Omnia Unlocked Cellular...
What is fixed dailing number
If you turn on fixed dialing, you can only make calls to contacts that appear in your fixed dialing list.
You can make an emergency call when fixed dialing is turned on, even if the emergency number does not appear in your fixed dialing list.
If your wireless service plan includes SMS text messaging, you can also send SMS text messages to contacts that appear in your fixed dialing list.
Feb 24, 2011 | Computers & Internet
My LG Xenon does not receive or send any text messages.
hi there my lg gr500r receives messages calls and all but it wont let me reply by sms text message. ive turned it off and on and taken out the batt but it still wont send out messages. on my message settings i go into message centre number and it is blank. dont know why... but i dont know how to input the message centre number. is there a key on the keypad that i have to push in order for me to input the number coz it wont let me dail it in? thank you
Dec 15, 2010 | LG Xenon GR500 Cell Phone
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
Can not send text messages from my nokia 5230
reset your setting by hardly reset with code "*#7370#" dailing. First get out your sim card and memory card.
Apr 02, 2010 | Nokia 5230 Cell Phone
Cant send text messages
contact your network operator and ask for the message service centre number then enter this into your message settings and this will work no problems
Apr 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
Samsung Exclaim M550 Cell Phone Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
