Question about Cell Phones
I have a cricket a100 phone, and when i dont have cricket signal, it beeps and it says ''out of coverage''. and it starts beeping in class, and i dont like turning it off. how do i take the beeping off?
3 Suggested Answers
  • 38 Answers
SOURCE: Loss of signal alarm
Go to settings, then scroll to network and turn the service tone, Network jingle off call drop tone OFF
Hope this helps
Posted on Jul 20, 2008
  • 8404 Answers
SOURCE: i dont know the 4 didget code to my cal-comp a100 cricket phone
try the last 4 digits of your number
Posted on Oct 10, 2009
When i dont pick up my messages the phone beeps like a busy signal i have a panasonic model # K X TG 5671 its after the message is over it beeps
Many of the telephones have a built in answering machine. The beeps are to let you know you have a message you have not picked up yet. This to help you not miss messages. Check your owners manual to see if you can turn off or mute the message warning tone.
Oct 05, 2014 | Lands Phones
Continuous beeping
You have a faulty key on the keyboard. Replace the keyboard, they are not expensive. Look at ebay for prices.
Feb 06, 2014 | Computers & Internet
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
My pc is not running properly when i start it. it's a single long beep and then two short beep . WHAT IS THIE SIGNAL?
this is the signal that your ram is not working.U need to chande your ram...but first eject your ram clean the ram and ram port then put the ram back then check if its still beeping then it means u will have to change your ram.....
Plz dont forget to rate thnx
Sep 08, 2009 | Intel Desktop Board D845WN Motherboard
Model 21518 GE Bluetooth Telephone Adaptor
I see the same thing and it appears that this is the way it works. Without the landline you will get the beeps but can still make and recv calls. After the beeps, dial #1#phone-number#, and it will call that number. Guess that is what they mean when say works without landline.
Apr 12, 2009 | GE Lands Phones
Cell Phones Logo
109 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
