Question about Whirlpool Calypso GVW9959K Top Load Washer
Error code CA on calypso - Whirlpool Calypso GVW9959K Top Load Washer
  • 26 Answers
Http://www.applianceaid.com/calypso-codes.html#wash
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Posted on Sep 27, 2009
  • 530 Answers
SOURCE: CA error on washing machine
sounds like you have a bad motor controller board. there is a fuse on this board it's directly behind the consol on the left side. check the fuse if it is bad you know that is what your problem is.
Posted on Jan 04, 2009
  • 351 Answers
SOURCE: CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
Posted on May 08, 2009
  • 51 Answers
SOURCE: Sears Calypso Washer purchased in 2004, displays
CA - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
Posted on Jun 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite calypro CA error code. Plus makes
The CA indicates that an average current limit on the drive motor has been exceeded (see images below). This is an extremely hard problem to diagnose and one that I've seen cause the best service techs to pull their hair out. It can be one of so many different components, and you have to catch conditions just right to have half a chance to discover which one it is.
Try removing some of the clothes; this could be caused by overloading. You could have a mechanical failure in the universal joint, wiring harness, the drive motor, central control, or the motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code c1 of ca
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Posted on Sep 23, 2010
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
I ran a self diagnostic test on my Whirlpool calypso washer and got CA error code. Do I need to replace the drive motor?
Before replace, I would first check the power supply, wiring and electronic.
Dado
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine has an error code of "CA" What does this mean, it is squealing and will not drain water
CA means average current limit . this may signify problems with drive motor or motor controller over loading the washer may cause this problem. to clear this-press stop /cancel
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso kenmore washing machine faulty spin cycle ''CA'' code
This code signifies that there may be a problem with the motor, thermal protector or motor controller. Overloading the appliance may cause such an error code. Try using a smaller load. If the code reappears, contact an appliance service company.
Apr 13, 2010 | Kenmore Washing Machines
I have a ca code what does this mean
Hi
Thanks for using FixYa. Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Sears Calypso Washer purchased in 2004, displays the CA error code. Unplugged the washer for a couple hours and replugged in. Ran a cycle without anything in. Worked fine. Placed a load in and it ran for...
Jan 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
486 people viewed this question
Dan Webster
Dan Webster
Sal De
