Question about Rockford Fosgate Punch Stage 3 P38D4 Car Speaker
Cracked sub woofer how do i patch it? - Rockford Fosgate Punch Stage 3 P38D4 Car Speaker
    Problem Solver:
  • 10 Answers
If its the ring around it fingernail polish works and the cone u can use superglue arounf it with a piece of electrical tape
Posted on Sep 29, 2009
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
The sub-woofer output on the receiver is not working. I have tested the sub-woofer (speaker) and it works. And I have tested the cables and they work. The problem lies within the receiver. How can I fix...
I don't have the manual, but if YOU do, crack it open and find the part where you tell the receiver it HAS a subwoofer and any other settings that direct bass toward it.
Apr 18, 2010 | Sherwood RVD-8090R Receiver
Power to subwoofer but no power to SA-HT692 receiver.
I had the same problem although not in storage but it just lost power to the console. It turns out that when I press down on the cable connecting the sub woofer and console, at the back of the sub woofer, I temporarily get power to the console. I did that for long enough to eject my DVD's and then opened the back of the sub woofer to fix it and cracked the board and broke it forever.
Sep 20, 2009 | Panasonic Audio Players & Recorders
12'' sub woofer
cone is cracked if you see the crack sometimes epoxy or rubber glue can wrok but Id ship it back to audiobahn if under warranty otherwise buy another one as shipping and repair gets expensive
Apr 25, 2009 | AudioBahn AWES12P 12" Subwoofer Car...
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Sub-Woofer
you must replace the board with new one.
Jun 01, 2008 | Panasonic SC-HT930 System
Car Audio & Video Logo
85 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
