Question about Toshiba CF32G50 32" TV
Toshiba Color Television CF32G50
This TV was made May 1998.
It turns on and has sound. There is no picture. What can be the problem?
I'm not a tech but would it cost a lot to get it fixed? Or should I just get rid of it?
Thanks!
Rob
I have a toshiba cx36H60 sound no picture
Posted on Jan 09, 2009
    President:
  • 4,402 Answers
No picture displaying but sound coming through ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 21, 2014 | Bush 5693D 24" TV
Why does tv have double color picture appears in three d?
u need a tech to reset the tv convergence problem the cost depends with the tech and your area check with your nearest tv repair shop
Jul 11, 2013 | RCA P61930BL 61" Rear Projection...
Lots of Blue shadows off to side. concaved picture almost
HI, this is a failed convergence chip that is located on the convergence board. it will need to be replace ASAP. you can just replace the chip or , you can order a new board.
Replacing the chip can be a rough job if you don't have tech experience. if you are a fluid tech and you can solder and know your way around a circuit board, just replacing the chip will cost less. if you are not an experienced TV tech, i recommend a service call to the nearest TV tech to replace the convergence board.
May 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
1998 panasonic projection tv,it is getting power,all three bulbs
This is a problem with the vertical section,
You should have a tech look at the set for you.
repair cost should be from 160 to 280.
usd vertical problem.
Jan 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No picture but I have sound
Dificult to say there can be a lot of stuff that could go wrong. Sory you must take it for repair at your nearest tech.
May 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Have sound but no picture
YOU HAVE A BAD CONVERGENCE IC ON THE CONVERGENCE CIRCUIT BOARD-THIS PART CAN BE REPLACED ,SAVING SOME MONEY,,COULD ALSO BE A LOOSE CONNECTION ON THE IC...PROBABLLY NEED TECH ON THIS ONE --COST 'BOUT 100.00 TO 125.00!
Aug 04, 2007 | GE 46GW945 46" Rear Projection Television
Hitachi 42" plasma TV (42PD6600)
IF you are saying that every thing is connected properly check your video cable it could be bad use a new one if that does not rectify your problem it is time to call in the tech you could be having problem in your video circuit but you did not mention if the screen light up with no picture but with sound or it does not light up blank with sound.however there could be two things 1 if the screen lightup with normal sound it could be a leaky ,open, or shorted, transistor or ic in the IF circuit.2 If the screen does not light up and has normal sound it could be a defective horizontal stage.so it is time you take the set to a tech for repairs.good luck.
Mar 26, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Power but no picture or sound
Is hard to tell if the set is going to need parts or not,maybe not,since you protected the set from dust is not likely the cause of the problem,after a while the units develop loose conections because of the heat dissipation some components have and the solder conections become loose.Be safe and seek assistance if you are not too familiar with tv service.
Sep 27, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Televison & Video Logo
193 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
