Question about Samsung SGH-d807 Cellular Phone
The phone does not startup only comes on and off
How to change a n70 to online mode?
IF YOUR N70 IS SHOWING OFFLINE MODE PROBABLY BECAUSE IT DOES NOT READ YOUR SIM CARD OR YOU SELECT YES AT STARTUP. REMOVE YOUR BATTERY AND BRING OUT THE SIM, REINSERT PROPERLY AND STARTUP YOUR PHONE, THERE SHOULD BE A MESSAGE ON STARTUP " DO YOU WANT TO STARTUP PHONE IN OFFLINE MODE?" PRESS NO, (LEFT UPPER KEY) PHONE SHOULD STARUP ONLINE OTHERWISE YOUR SIM CARD IS NOT BEEN READ.
Nov 13, 2011 | Nokia N70 Cellular Phone
How do I choose startup android (2.1) apps?
You can specify which applications you want to start up by downloading the application, "Android Startup Manager."
Step 1: Launch the Android Market.
Step 2: Search for "Startup Manager" from DownloadAndroid.info"
Step 3: Download the application. It's free!
Step 4: In the Startup Manager's application list, uncheck the checkboxes next to any applications that you do not want to run automatically when your phone is turned on.
Step 5: Check the boxes next to any applications that you would like to run automatically when your phone is turned on.
Step 6: Restart your phone to ensure that the changes have been applied successfully.
That's all there is to it!
Mar 01, 2011 | LG GT540 Cell Phone
When i turn the phone on it comes up with offline mode
Insert the SIM card properly. When it detects the SIM card upon startup, it will give you an option to quit offline mode.
Dec 06, 2009 | Computers & Internet
"sim not valid" problem
This problem can't come on startup. It usually comes after the phone asks Sim PIN and after entering the PIN, the message comes " Sim not Valid ". First make sure that the phone's Sim is unlocked. Also note that it can be a faulty Sim. Also remember, have you entered a different carriers Sim. If yes, it will ask for Sim PIN. If it is entered incorrect then it will say the Message. Also check that is the Sim faulty. Try confirming by trying the Sim on any other phone.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Nokia 2310 Cellular Phone
I hace a cect i9 phone still in box, but will not turn ON. It worked the first day I bougth it cause I tested it.I have charged the battery but still will not turn on. Is there a service location in...
you should have 2 batteries with it ...take battery out put other one in making sure in correctly seated...plug into pc via usb see if charging icon comes on ...once enough charge in to startup phone try other battery ...when charging you can press and hold top button on phone to startup if enough power...
Sep 11, 2009 | Dual Electronics CECT P168 Cellular Phone
Nokia N95 is not starting up
Your phone has Start up failure problem. You have to flash your phone and then install new firmware of your phone. There is just software problem with your phone.
Jun 26, 2009 | Nokia N95 Cellular Phone
No startup - it make start again and write error in startup
it is the software problem my dear, you need to refomat it
May 24, 2009 | Nokia N76 Cellular Phone
Stuck on startup screen
it looks like your software firmware is damaged and your phone will need 'reflashing' this can only be done at a phone shop and should not cost too much
May 04, 2009 | Samsung SGH-G600 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
65 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
