Missing Chip I have a Franklin Digital clock I found. It is missing I.C. U9 on the 1104B circuit bd. I was wondering what the Chip # is? The Model of the clock is MP256-100021. Thanks for the help.
  • 797 Answers
Look it up on the Internet. Most of these kinds of things are listed. You may get help someplace from an electronics repair man as well.
Posted on Sep 27, 2009
Some of the segments in the numbers on the face of the clock have disappeared. Why?
Possibly the segments have failed or the driver chip has partially failed.
The contact between an led or lcd display is not always hard wired to the circuit board where the driver chip is located. Often the contact is made by sandwiching a conductive flexible strip between the display and the circuit board.
The initial assembly is carried out in near operating theatre conditions and once assembled the system provides a cheap solution that has proved fairly reliable in most cases. In some cases a few years of heating and cooling and being bombarded with atmospheric dust and moisture and vibration will spoil the connection.
While it is usually fairly easy to take the connection apart for a very thorough cleaning, it is the thorough cleaning that is far more difficult than it sounds and the usual outcome is to restore the missing segments and lose some of the others.
Complete success is possible but not assured.
Mar 02, 2016 | Home
Front LED just Cycles white then goes red. Replaced lamp did not fix set. Found 5 volt power on command missing from Digital bd to DMD bd. Need to replace Digital main bd. Part needed is 6871VSMS28B. Will...
Good day!!!
if the command signal from main board to DMD board missing the problem could be the main board..
I already found the board online for only $75 on this site http://www.discounttvparts.com/6871VSMS28B_p/td-1169.htm
$100 on this site http://www.ebay.com/itm/NEW-LG-MAIN-UNIT-6871VSMS28B-6870VS2273C-/260877125964
Hope it helps..
just add a comment for any follow up questions..
Thank you
Jan 26, 2012 | LG 62SX4D 62" Television
I purchased the franklin dual court basketball for my boys for a gift and the sides and the bottom piece that brings the ball back to you is missing I took it back to the store and I do not have the...
You can purchase the parts off of franklin sports website. Theyre 14.99 each plus shipping.
left: http://www.franklinsportsparts.com/14281s11z1.html
right: http://www.franklinsportsparts.com/14281s11z2.html
Feb 14, 2011 | Video Game Consoles & Games
Red vert lines will not convergenge(sides) blue and green o.k.
your convergence output amps are done...
you have to do repair on the convergence output circuit, and inspect
the power supply for any damages.
Jan 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
Missing slide bolt
send it to your local gun store and see if they can fix it....
Dec 28, 2008 | Crosman (4032)
Model CF1926A TV with insufficient vertical height. I replaced c308, c305, c301, c315. voltage was missing from ic501, pin 29; restored with replacement of c301. no help to vertical. voltage was missing...
I think you missed one cap. Look for another 1ufd cap close to the jungle chip. It will have the circuit designation in the 300's like the others in the vertical circuit. It is just not located close by. I think that one will fix it.I don't have the service data with me so I can't give you the exact designation.
Dan
Jun 04, 2008 | Toshiba Televison & Video
Computers & Internet Logo
David Payne
David Payne
