Question about Maytag MTB2156GES Top Freezer Refrigerator
Freezer door will not shut tight. It is like I
Freezer door will not shut tight. It is like I can not get a seal on it. I checked and nothing seems to be blocking it.
appldoctom
  • 311 Answers
SOURCE: freezer door won't seal
you have to be the eyes here.look for tho obvious its not going tobe mysterious.the gasket is magnetic and the magnets dont wear out.look for the point where its stoping it fro closing
Posted on Jan 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: my bottom freezer door isn't aligned right the
Don't think buildup is the problem. Sometimes the doors become loose and need adjustment.1a4bfab.gif See if you can locate the model serial number so I can help you better, Sea Breeze
Posted on Mar 27, 2009
philbran
  • 242 Answers
SOURCE: changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Posted on Jun 10, 2009
  • 50 Answers
SOURCE: I've checked door seal for leaks, etc; made sure
You can clear the drain tube by gently reaming with a wire hanger.
Blockage won't cause it to freeze up so quickly though. Check the thermostat setting? Otherwise it is very likely that the thermostat is not deactivating when it should. This would require replacement of the thermostat.
Posted on Sep 06, 2010
richroth
  • 9472 Answers
SOURCE: the seal around the freezer door is not fitting
Here is a link to the replacement door seal.
Posted on Sep 12, 2011
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Side by side kenmore refrigerator no suction on produce side
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
Apr 18, 2012 | Kenmore Refrigerators
My bottom drawer freezer (kitchenaid) is accumulating alot of frost and the door seal seems like its not sealing
You need to clean the bottom of the door seal and then kinda fluf the seal a little bit by pulling on it and allclean out all the frost and make sure nothing is in the way of the door shutting tight.
Jul 07, 2011 | Refrigerators
The refrigerator door side does not shut tightly. The gasket seems to be ok and we leveled the unit. Still not shutting tightly like the freezer side which seems to have a magnetic pull to assist close....
Check bottom hinge cam riser located on bottom hinge the pin that goes inside the door it's plastic it's a 2 piece part 1 part goes over hinge pin and the other goes inside door hole. They get worn and break. If you replace this make sure you get both parts until you do try adj. top door hing to get the door tighter.
May 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a Frigedaire Upright freezer, Model says
to verify what i think could be the problem i would need the complete model number so i can recheck what i am about to tell you
the freezer has a heater where the door gasket seals itself on (not on the door behind gasket but on the freezer itself) see if you can feel if it is warm where the gasket rest on the freezer this help it get that solid air tight seal. and prevent ice build up on gasket
well this maybe one possible without being there its alittle hard to tell what else hope this was alittle helpful
Mar 13, 2010 | Freezers
Refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Maytag MTB2156GES Top Freezer Refrigerator Logo
32 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
