Question about Swanstone MS-2424 Stone Composite Mop Service Sink in White
I have a double sink and the left sink drain leaks
This is a swanstone sink
I have a double sink and the left sink drain leaks because the "washer"(?) has rotted. the right side is still very good. When I look under the sink the washer is located immediately under the sink and the basket attaches dierctly to the drain. The material is white plastic(?) and does not seem to be something that can be turned.
  • 61 Answers
There are a few different designs of basket strainers that are common.
All of them that I have ever seen threaded together in some way.
From the bottom, try to turn the strainer to the left.
Sometimes they can be rather difficult to turn due to corrosion, but it will certainly take some force to get it to move.
Unfortunitily, the amount of force normally required is something learned with experience
Posted on Oct 27, 2009
  • 31 Answers
Ok if you go to real plumbing store i do not know where you are but they have the "washer"{ gasket } you would take out the sink only slides in to drain it is pretty tite replace your gasket and all new again
Posted on Oct 02, 2009
I have two little round stains on my Swanstone kitchen sink and I would like to know how to get them out. I dripped liquid skin in small part of the sink and everything I have tried does not work. A
You will lose any gloss you may have left after 20 years, but i'm pretty sure Swanstone is similar to Corian in that you can sand the stain out. Start with a 180 grit and after the stain is removed you will want to wet sand it with a 250 to 400 grit.
Oct 09, 2014 | Swanstone KSDB-3322 Double Bowl Kitchen...
I bought a new kitchen sink and pipes with a garbage disposal. Over night the smell in the garbage disposal is like rotten eggs! How can I make it smell good?
Use hydrogen peroxide and/ white vinegar to safely deodorize disposal.
Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Swanstone KSLS-3322 Double Bowl Kitchen...
Replacing a double kitchen sink ?
You can just replace drain. It would be called a Basket strainer.Remember my saying when you purchase these.Price is forgotten while Quality remains
Feb 01, 2012 | Home
How would the swanstone kssb-3322-015 black galaxy look with black galaxy countertop? Thanks!
They will always look great with any back ground of counter top due to their unique look and under slab mounting.........Great choice........Hope this helps.
Apr 19, 2011 | Swanstone KSLS-3322 Double Bowl Kitchen...
Cut a small line through swanstone granite sink when installing undercount . Fixed with epoxy. Will that work?
It should work, I would imagine it's pretty conspicuous, but you shouldn't have problems with leaking if the epoxy filled the hole completely. I would clean the repair on the outside of the sink with rubbing alcohol, then put a decent amount of silicone to completely cover the repair area to insure no water gets through if there are any compromises in the epoxy.
Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Feb 26, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
PROPER WAY TO COMPLETE KNOCK OUT HOLES FOR FAUCET
yes you need 1 1/8 in hole saw,for granite.Also need a squirt bottle to keep the bit wet,try to google ,DIY they might have a video on this .
Apr 12, 2010 | Swanstone KSDB-3120 Compact Double Bowl...
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
Swanstone MS-2424  Stone Composite Mop Service Sink in White Logo
183 people viewed this question
Top Swanstone Plumbing Experts
Donni Steen
Tom Chichester
Are you a Swanstone Plumbing Expert? Answer questions, earn points and help others
