Question about Acer Computers & Internet
How do i charge my acer laptop? - Acer Computers & Internet
    Sergeant:
    Champion:
  • 289 Answers
You plug the charger into the wall then if there is a light on the cord or the box it is working. Then you plug the other end of the cord into the back or side of the laptop where it fits. Next time say what laptop, please! Also, If you don't have a charger search the name of your laptop model then put charger at the end of the query and buy one, because it won't last that long without a charger.
Posted on Sep 27, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
My acer aspire 4937 had a problem in charging. If I open the laptop then put the ac adaptor, the charging does not move or does not charge. Then when the laptop is shut down the charging is ok. What is the...
This is due to the faculty volume control panel at the right. I have same problem and acer replaced the volume control panel. It seemed this is a known problem to acer.
Same problem come back again and since my notebook is out of warranty, i will try to remove the volume control panel wire connected to motherboard.
Dec 04, 2010 | Acer Computers & Internet
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
ACER ZG5 Laptop: Cannot charge my laptop.
The fix for this would be expensive. You ned to take it to acer repair. you can make this repair your self
Oct 10, 2009 | Dell Latitude D600 Notebook
Battery will not charge on netbook
Sounds like it may be an internal problem with the charge system on the laptop, if you can run the laptop with the AC cord but it will not charge, I suspect the charge module is bad.
May have to return it for repair.
Sep 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
371 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
