Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace lamp? Can I do this myself or do I have to get a repair man?
  • Zenith Master
  • 8,457 Answers
There a lamp sign the screen right?Put on sergical glove so don't leave finger prints or human sweet could damage somthing else when,power is back to tv for operation.U have a little electronic experience right?U could do it ur self.
Posted on Sep 27, 2009
    Genius:
  • 1,112 Answers
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
I replaced my bulb 6912V00006C on my Zenith E44W46LCD and when i plug the TV back in a red light comes on. when i press power a green light blinks for 5 seconds and then goes back to the red light. I don't...
YES, this set is difficult to replace the lamp correctly---it is very likely when you put the cartridge back into the set the two pins on the back did not properly engage inside the set.
Remove lamp and try again, if set was working before and now different problem, the lamp is not properly seated.
If I remember this model, just the bulb is available, you have to take the housing apart and replace bulb--if not perfectly done plug on back with two pins will not engage.
SD TECH
Sep 10, 2010 | Zenith E44W46LCD 44" Rear Projection...
TV wont turn on
The main power supply is failing or it is shutting down because of a fault on the output side of it and it is trying to protect itself from overload which can cause a fire. Contact Zenith customer service and describe the problem, particularly the flashing LED which may be giving you an error code.
Sep 04, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
ZENITH TV MODEL #E44W46LCD
you must replace your optic block assembly.
Jan 05, 2009 | Zenith E44W46LCD 44" Rear Projection...
Volume lowers
replace digital board. A hardware update is available that might solve it.
Feb 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Light flashes, bulb fires, no LCD!!
Sounds like the ballast is faulty or else your lamp is getting close to needing replacement. Hope this helps.
Jan 16, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
169 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
