Question about Car Audio & Video
I get a pop from the sub when the power comes on.
I installed a new deck now when the power comes Iget a pop sound from the sub.
    Habit-Forming:
  • 159 Answers
This is caused because the stereo you have put in, is a high power output, or higher than the factory and puts that extra power into the factory amp systems causing the amp to surge the power to the speaker resulting in the pop sound,most newer cars use a stereo system without an internal amp so as to reduce heat and a external amp in usually under a seat or dash and a high power stereo boost the output of the amp.
Posted on Sep 27, 2009
Sub problem with kenwood deck
well sounds like you crossed a wire somewhere. I would go through all the wires and check all the fuses on the amp and car.
Apr 10, 2014 | Kenwood Car Audio & Video
I have a fairly good sound system in my jeep cherokee, new speakers, deck, new battery, rca cables, and a new box for my subs. But recently i've been dealing with some problems. i've had my amp grounded...
there are really only 2 causes for this.
  1. grounds. Make sure the grounds are clean and tight and all paint and dirt was removed before they were fastened.
  2. Your alternator is starting to go bad.
I would lean toward the grounding problem as you have said you just changed them. Also make sure the grounds are as short as possible.
Dec 24, 2009 | Car Audio & Video
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
My alpine deck is not seeing the sub woofer
deck rca opt check voltage should be round 2 4 volts ac check gain on amp if u have low volt from deck sound will be dull
Apr 03, 2009 | Car Audio & Video
Amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Mar 15, 2009 | Kenwood Car Audio & Video
Just installed my cva-1004 in my truck and all connections are good get dvd picture but no sound do i have to have the remote to select inputs i also hooked amp and subs up amp to the sub rc's at the back...
Hey Ryan I have the same thing dude has and my sound only works when I have my subs are hooked up. Without my subs hooked up I have no sound at all. Do you know how I can fix this?
Jan 26, 2009 | Car Audio & Video
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio & Video
Sony 1200 watt amp
What kind of deck to you have? Sometimes there's a setting for the subwoofer output that has to be turned on. How is the deck hooked up to the amp? Be sure of the normal things: -Make sure the sub is connected in side it's box -Make sure the RCA cables didn't come off the deck -Check every connection! Let me know and be sure to leave feedback or I don't get paid.
Oct 03, 2007 | Sony XM-2002GTR Car Audio Amplifier
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Jul 08, 2007 | Panasonic CQ-C8803U CD Player
Sub is getting no sound
Sounds like you answered your own question when you said you were getting no sound from your deck to your sub.
Jan 23, 2007 | Koiiler XM-6666W Car Audio Amplifier
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
