Question about Creative Labs CT4170 Sound Card
No sound at all, have linux not windows.have sound blaster model ct4170 and am runing utubo 9.04 desktop x386, what can i do myself?
    Problem Solver:
  • 5 Answers
Hi richbax,
the soundcard you are currently using (Creative Sound Blaster ct 4170) is supported using the ALSA sound driver/server, you can activate it by:
1- verify the soundcard device is detected properly by issuing a lspci command from the terminal/console or command prompt
user@localhost# lspci
2- if Creative Sound Blaster ct 4170 is listed, proceed by issuing a alsaconf command to activate alsa server to use your sound device
user@localhost# alsaconf
3- then issue a alsamixer command to activate and adjust sound volume
user@localhost# alsamixer
4- press escape key then issue a alsactl store command to save setting and restore after bootup
user@localhost# alsactl store
Posted on Mar 26, 2010
Sir i h've sony vaio e series vpceb14en modal no. and runing the linux 5.4 operating system bt my laptop suffering some problem when i configure ip address,wirless conection, sound problem,screen...
First I need more information on your LINUX... what is the base??? I presume Red Hat 5.4?? what is the Desktop distribution (if using a desktop)???, what are the exact make and model numbers of the peripherals that are not working in the computer (video card, lan card, sound card)??? did the computer came with Linux pre-installed??, I'm more of a DEBIAN base Linux with a Gnome desktop distro user... but maby I can help... also what are the exact problems with all those cards??? starting with the network card... (one problem at a time)
see ya soon!
Mar 26, 2011 | Computers & Internet
I have sound blaster CT 4170 in my main board but I have not its driver kindly help for this.
You can download the audio driver from the Creative WEB site. Please click on this link and select your model sound card to download :-
http://support.creative.com/
Oct 01, 2010 | Creative Labs CT4170 Sound Card
I need to install epson sx115 for linux unbutu 9,04 where can I downloade the file?
It should automatically get detected and installed by UBUNTU. You just need to connect it and use it
Oct 05, 2009 | Epson Computers & Internet
Sounblaster ct 4170 for xp driver help
http://www.bioticaindia.com/sound-blaster-ct4170.html
Sep 02, 2009 | Creative Labs CT4170 Sound Card
Linux driver for Sound Blaster 4170
hi jsimons452,
Jul 08, 2009 | Creative Labs CT4170 Sound Card
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(ISOLATE PRESERVE)
(IDENTIFY *)
(VERBOSITY 2)
(CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING (CONFIGURE CTL00f4/-1 (LD 0
(INT 0 (IRQ 5 (MODE +E)))
(DMA 0 (CHANNEL 0))
(DMA 1 (CHANNEL 1))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
(ACT Y)
(WAITFORKEY)
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
snd-card-0
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
Ted
May 23, 2009 | Creative Labs CT4170 Sound Card
Pipe internal PC speaker sound through Sound Blaster 16.
The 2 outer pins of the four pins on *********** board are the + and - pins for the speaker.
Dec 03, 2008 | Computers & Internet
The Creative Sound Blaster Live 5.1 Card is not working Or detecting in windows vista
Creative doesn't have Vista drivers for that video card so unless you use some hacked drivers it probably wont work.
Oct 09, 2008 | Creative Labs Sound Blaster Live! 5.1...
Creative Labs CT4170 Sound Card Logo
130 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
