-   beans are in the grinder, water's in the bin, turning it on results in beeping.
just beeping,
signed,
CUPINHAND-   cupinhand
Jan 25, 2008
-   im having the same problem with my maker--turn it on and within 5 seconds it beeps like it has finished brewing -ive only tried to pull the bottom off to check things,but my torx driver wasnt long enough to reach the last screw and i stopped at that point -   wjmullin
Jan 02, 2008
-   When I try to make coffee following the directions and press on the on/off button, the water will not heat up and come through the top into the container that contains coffee grounds. Shortly after I push the on/off button, the coffeemaker beeps 5 times, indicating that the brewing has finished. Then nothing else happens. The coffee warmer does gets a bit warm. (The grinding phase works fine.) I checked all the hoses and the water seems to flow from the water container into the heating element. It seems that the element is just not getting the water hot enough to get to the right temperature and push it into the grounds. -   spikewave
The constant beeping means that something is out of place. Take apart the coffeemaker parts completely and put them back in their proper place (don't forget to close the lid). The beep should stop. If it doesn't stop, unplug the unit for one hour and call Cuisinart to see if it is still in warranty.
-Tha Mp3 Doctor
Was this helpful?
Yes
No
Popular Solutions for Cuisinart DGB-300 Coffee Maker
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have...
(More)
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have follwed the steps in the manual. It doesn't make any noise as if attempting to grind. The grind processed is by-passed going straight into the brew mode. We used the non-grind for about 2 weeks. Thank you.
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go,...
(More)
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go, but now just beeps again. All parts are in place and water is in resevoir.
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of...
(More)
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of coffee - just started doing that. Unit was cleaned 3 months ago. Fred
