Question about Motorola Mobility RAZR V3
Change external display, razr v3 - Motorola Mobility RAZR V3
Loose "flip" (display) on a Razr v3. How can I tighten it..??
You may need a new Flip assembly.
The version might depend on your model of V3 (RAZR)
May 22, 2008 | Motorola Mobility RAZR V3
Motorazor V3 External Display not working
hi racie,
1st i want to tell u that there are 2 types of diplay in flip mobiles like urs. and there are 2 display LCD plates/chips inside it.
One of the LCD plate/chip of the external display is damaged. It is due to hard flipping of the mobiles.
I recommend u to go to mobile technician coz it is a physical problem.
Looking for ur kind feedback,
Sajan (sajwhat_2003@yahoo.com / sajwhat@hotmail.com)
May 05, 2008 | Motorola Mobility RAZR V3
External display
you can try and do a master reset and master clear that should fix the issue.
Jan 08, 2008 | Motorola Mobility RAZR V3
Razr external display
Has the phone ever displayed this information?
First try Enabling Caller ID, if that doesn't work then Shut Down the phone, remove the battery, then replace the batter and try again.
Dec 28, 2007 | Motorola Mobility RAZR V3
External Display
It's most likely a bad LCD you might have to send it in to be repaired, since the internal display is the only one that can be controlled, but I might be wrong on that.
Hope that helps.
Dec 26, 2007 | Motorola Mobility RAZR V3
External Display Screen
you just need to get the external LCD replaced...not to worry most lcds on the v3 you can take out the external lcd without replacing the entire lcd....so take it to a repair center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
External Display
This is a hardware issue. The flex cable connecting the displays is loose or broken. If the phone is new, you can get this repaired under warranty.
Dec 01, 2007 | Motorola Mobility RAZR V3
Date display on screen?
This sucks! I have the same problem.
Sep 11, 2007 | Motorola Mobility RAZR V3
Motorola RAZR
your external screen needs replacing...you would have to take it to an authorised repair person to replace it because it's very tricky to change. Sam !
Sep 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
