Computer won't turn on won't do anything , i had it connected and someone at my house was using electric drills and the fuse tripped and everything was shut down including my computer and since then it won't turn on or do anything for that matter can you tell me what happened
    Scholar:
  • 95 Answers
Try unplugging the computer completely from the wall for 15 minutes. Plug it back in, and see if it will power on.
If it doesn't it's most likely a blown power supply, when the breaker tripped, everything on the circuit basically fed back into everything plugged in. This is something most computer power supplies do NOT like.
The good news is, a power supply is generally pretty cheap, you can get new power supplies atarting around 20 bucks, although decent quality ones are closer to 50 bucks. Bad news is, there is about a 1 in 20 chance the power supply took other parts with it.
Once you do get it running, or get another computer, make sure to get a surge protector strip and plug everything connected to the computer into the surge protector. A 15 dollar surge protector can save you 150 dollars in parts and labor. (or more)
Posted on Sep 27, 2009
Testimonial: "thank you i'm going to try getting a new power supply and see if that works, i tried unplugging it and plugging it back up but nothing happened"
    Sergeant:
    Champion:
  • 232 Answers
You may have burned a fuse .
try to look at the back of the fan unit , depending of the PC you could have a fuse externally accessible , otherwise you may have to open the box and look for the fuse in the power / fan box .
Make sure that your PC is unplugged prior to any touching inside .
you open the box at you own risk .
Why does it blow controller fuse when key is turned on?
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
fuse keeps blowing Drills & Drill/Drivers Questions ... - Fixyawww.fixya.com > Forum > Tags > fuse keeps blowingDrills & Drill/Drivers fuse keeps blowing questions and answers. Ask your fusekeeps blowing drill and drill/driver questions. Get free help, advice & support for ...Ryobi Multi-Volt Battery Charger Fuse - Questions - Fixyawww.fixya.com > ... > Ryobi > Ryobi Multi-Volt Battery Charger1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC. Question about Drills & Drill/Drivers. 1 Answer ...Remember that fuses can fail without showing signs of an obvious ... remember that suspect turn signal flashers, fuses, bulbs and relays can be ... will be predictable, such as a bad current or ground connection, blown fuse and the like. .... The relay then sends power to all the lock motors (all doors except driver's door).Missing: drills
[PDF]Electrical Safety - Occupational Safety and Health ...
https://www.osha.gov/.../4...
Occupational Safety and Health AdministrationShe has an older drill with a steel housing and a 3-prong plug. ... current. This willgenerally allow enough current to flow so that a fuse will blow or a circuit breaker is tripped, thus turning off the electricity in that circuit. ..... There are three major ways tocontrol power line hazards: 1. ... Install warning signs at driver's eye level.Missing: drills ‎key
Jan 07, 2016 | Drills
Everything electric in my house goes off and I turn my oven on and my electric comes back on. What can I do to fix this problem?
are you saying that all day long you have no electricity? It's only when you run the oven that your house is energized?
Jan 05, 2016 | Ovens
My treadmill turns on but completely cuts out and trips the house fuse box.. whats wrong
Either your Motor or Motor Control Board(MCB) is faulty.
Try testing your Motor with a Drill Battery:
1. Disconnect the machine's power lead from the power socket, so that there is no power to the machine.
2. Open the Motor Hood.
3. Disconnect the Motor + and - leads from the Motor Control Board.
4. Connect + and - leads(normally Red and Black) to the Drill Battery.
The Motor should turn the Belt.
With the Motor leads disconnected from the MCB, you can connect the machine to the power, Press Start, and if this trips your Fuse Box you know its definitely the MCB.
Only carry out these tests if you are competent.
Lethal Voltages are present.
samsfitnesssolutions.co.uk
Jul 04, 2014 | Proform Crosswalk 500 Treadmill
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
Was useing the oven and then everything stopped
Sounds like a house wiring problem or terminal block on the back of the unit. You seem to only have 110 volts to the unit. One of our connections may have burnt.(the clock thing I have seen many times, it is feedback.) Unplug the unit and check the wires from the unit and and to the house.
jim
Jul 27, 2009 | GE JD900WK / JD900CK / JD900BK Electric...
Maytag Ele. Dryer Model # lde7334a
There's no heat If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 31, 2009 | Dryers
Treadmill trips electrics
Check to see that the treadmill does not draw more amp than stated in the owners manual. If you are, then the problem is in treadmill. If not try another circuit in the house (not just another receptacle).
Jan 09, 2009 | Proform 380 CS Treadmill !
GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | GE Profile Harmony DPGT750EC Electric...
Computers & Internet Logo
210 people viewed this question
David Payne
David Payne
