Model av-48p777 jvc 48 inches I have the picture and sound but the pix is has lines through out picture. Like it out of focus (contrast) The power button has to be pressed on hard to turn on. It was made 1/07 do I have a warranty.
  • dsantiago726 Sep 27, 2009
    Now it turns off like it gettin too hot I read online about a fan were would it be located and its stil binking out of sync
    No luck I read about a fan or temperature. I plug in dvd and stiil did the same. Someone suggested that a hd card check. what else do i look for . Are those lamps expensive?
    President:
  • 1,462 Answers
The problem can be due to two things
1) It can be due to bad HYPER UNIT module. this is the digital scan card in the tv. try using the component inputs and if the tv works ok then you know that the HYPER UNIT is the problem.
2)If the TV doesnt even work with the component inputs, remove the front grill and then the acess pannel to the guns. You will find 6 knobs ie, 3 for color and 3 for focus, turn the focus knobs to the left and if need b the others also, and try to correct..
And your TV doesnt cover warranty
Please leave me comment, if you still need furthur assistance..
RNJ VINODKUMAR
Posted on Sep 27, 2009
Jvc 48 inch tv and the picture looks 3d
Convergence ICs have failed. You can get the convergence repair kit for your model JVC at www.tvrepairworld.com the kit contains both ICs the associated resistors and the CD with detailed instructions.
Jan 03, 2010 | JVC AV-48WP74 48" Rear Projection...
We had a bad storm and now my JVC AV-48P777 won't turn on. I have tested all of the outlets, but no luck. Help!
There is a fuse on the inside back panel that is suspect. Located near the power entry to the back of TV. Some versions were socketed others soldered.
Jun 10, 2009 | JVC AV48P777 Television
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Aug 30, 2007 | Televison & Video
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
No picture on tv screen
When you say no picture, is there any sound or noise coming from rear of set when you try to turn on. If so then you have no high voltage and maybe a cap in the HV line that is bad. If no sound at all, then maybe a fuse or open resistor in powersupply.
Jul 21, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
