Question about Motorola Mobility ROKR E8 Cellular Phone
Rokr will not turn on. Charge indicates solid yellow light.
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    My low fuel light is flashing, What does this mean? It is also very slow to indicate fuel level.
    Modern bike have a two stage fuel level indicator. Flashing then solid yellow. Usually you have 5 to 10 miles when you see a flashing yellow light and about 1 mile or less when the light goes solid. Older bike had a shut-off valve and a reserve switch. You turn the switch to reserve once you bike starts to sputter or stall.
    If the fuel light stay lit even after you fuel up then the sensor need replacing. That sensor in inside the gas tank.
    Aug 11, 2009 | 2004 Yamaha Road Star Silverado
    Rokr e8 won't charge
    when the phone discharges completly, it can olny be charged via the charger that plugs into a wall outlet.
    Aug 04, 2009 | Motorola Mobility ROKR E8 Cellular Phone
    USB plug to charge, yellow light not green
    t_cosh you must try charging it with the wall-charger, if that doesn't works, try entering BL mode by pressing # and *, and then pull the trigger to turn it on.
    It will tell you that battery is low, you can connect then the charger, pull the trigger again, it should start normally.
    Jun 21, 2009 | Motorola Mobility ROKR E8 Cellular Phone
    Once i charge my phone i get a yellow light rather than green.
    Leave it plugged in for a little while. When it's yellow it means that your phone is dead and it's charging up the battery. It will eventually turn on and the light will turn green.
    May 03, 2009 | Motorola Mobility ROKR E8 Cellular Phone
    Hp computer. hard drive light is solid yellow ..non working
    Hi 2xcapers
    This could be a problem with your IDE or SATA cables that connect your Hard Disk to your Motherboard. Try replacing these before you try the next solution.
    The constant yellow light usually indicates a crashed or non-functioning Hard Disk. You can take this to get repaired and only the data where the "Spindal Pin" crashed will be lost, otherwise the Hard Disk should still be fine. The screen does not come on during the event of a crashed or corrupted Hard Disk, so this is another indication that there is a problem with the Hard Disk.
    Please remember to give this solution a FixYa! rating.
    Happy Easter
    BearWeb
    Apr 12, 2009 | HP Computers & Internet
    Powering on
    OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
    Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
    I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
    Hope this works for some others.
    May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
    Motorola Mobility ROKR E8 Cellular Phone Logo
    104 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
