Question about Samsung LN-S4692D 46 in. LCD HDTV
Our TV has been great. Have owned it A little over 2 years. Just now the Volume line appears on the screen and the volume goes to zero without anybody touching the remote. The volume line stays on the screen at zero. What do I do?
  • Samsung Master
  • 8,457 Answers
Check the tv pannel manually control on the right,see if it work.Then it ur remote tries take it aparts clean it with some alchol with a Q tips there a screw under the batteries input,after that change the batteries,That one solution.The other have to take ur tv apart to change the sound board.
Posted on Sep 27, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Volume tv goes down its own
Depending on your TV, here are the generic steps Toshiba has outlined to reset your TV:
1. Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
2. Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
3. Highlight the SYSTEM STATUS menu at the top.
4. Highlight SYSTEM INFORMATION below and press ENTER.
5. At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
6. Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
Apr 09, 2014 | Toshiba Televison & Video
Insignia HD TV 32" has mind of its own (volume changes on its own)
The inbuilt software must have got corrupted. The simplest thing you do it get the software upgraded rather than just throwing away the TV.
Jan 18, 2012 | Televison & Video
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
My tv turned on on its own and does not respond to the remote, even after replacing the batteries. Furthermore, the volume goes up to 100 and down to zero on its own and the remote is not able to control...
check remote first,how to check remote switch on your camera phone point to camera lens,when press any key check screen light glow,you sure r/c ok.next check reciver eye of tv
Jun 27, 2009 | LG 32LC7D Television
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
Samsung LN-S4692D 46 in. LCD HDTV Logo
192 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
