Question about LG DLE5977 Electric Dryer
Lg dryer, motor works but not under a load - LG DLE5977 Electric Dryer
    President:
  • 1,462 Answers
Here are some things to be checked for your issue.
First, remove the access panel from rear of dryer and locate what is called the tensioner pulley.
Try lubricating it. may as well service it while youre in there.
Dryers are reasonably simple. lube all moving parts and clean.
Next,Check belt tension. if the tension is loose, the belt cant rotate the drum when it is loaded, Do it the tension is less, try replacing the belt and lint could also be a problem.
Please leave me comments if you need furthur assistance
RNJ VINODKUMAR
Posted on Sep 27, 2009
Gas dryer lg trom dlg5988B does not get hot.
If it has been under water you need to have it professionally serviced. The gas igniter is electronic and there are safety circuits to prevent explosions and getting gassed..
Nov 26, 2017 | LG Dryers
New drive belt on LG dryer to loose?
belt goes around drum the to the right of the tensioner and then to the motor pulley. you have to move the tensioner to the left to get the belt to the motor pulley. so the belt goes to the top of the tensioner, and around it in a clockwise manner, to the motor, not just under the motor and under the tensioner.
Sep 20, 2016 | LG Dryers
LG Sensor Dry DLE2301R power won't stay on unless I hold it down
There is a switch on the motor that could be bad or restricted with excess lint build up.
May 01, 2014 | LG DLE2514 Electric Dryer
LG dryer wont start at times and will at others. If I spin the barrell it will work on speed dry only. Any other selection and it just makes a buzzing sound.
The belt may be too loose or the motor is over loaded. In worse case you need to replace either the motor or control board.
Sep 07, 2013 | LG Dryers
Shutting off won't start when hot
The windings in the motor are bad and the motor will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
I have a LG DLE0332W Electric Dryer. I push the
Yes, the motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are LG certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide. The motor itself should be under $100.
Best, G
Aug 03, 2010 | LG DLE2532W Electric Dryer
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
LG DLE5977 Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
