Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I HEAR A RATTLE WHEN THE MACHINE IS IN SPIN CYCLE. IT SOUNDS LIKE SOMETHING IS UNDER THE BASKET.
  • 26 Answers
Do you have kids? My sons were bad for putting things in their pockets. Rocks, sticks, nails. Anything they were fiddling with outside. Many a times a small pebble or small nail would slip through the holes and make 'music'.
Now they are teenagers and when I do laundry I tell them if I find money in the machines it is mine. Guess what? They check their pockets good! XD
Posted on Sep 27, 2009
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Whirlpool spin cycle rattling
Well, it just might be. :-) More than likely you have something in your machine basket that is loose. Probably a coin or something from clothes previously dried or washed in the machine. This is quite common, especially for folks who carry coins or loose objects in their pockets. Remove whatever is loose in the basket and you will have solved your problem.
Jan 03, 2015 | Whirlpool Washing Machines
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washer model 110.23812100. basket not spinning during spin cycle.
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23812100
Also see the Whirlpool Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you can hear the motor and the washer drains during the spin cycle the Motor Coupler and Lid Switch (the usual problems with these washers) are not the problem.
These washers use a clutch which allows the "basket tube" to spin up to speed during the spin cycle.
If the clutch bands or springs are worn or damaged, the transmission cannot transmit power to the basket tube for spining.
See the following on how to remove the cabinet,agitators, basket, pump, transmission and basket tube. (It's not as difficult as it sounds.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Instead of using a special spanner wrench on the spanner nut, I've used a short 10" pipe wrench hooked onto one of the tabs on the nut and tapped the handle with a hammer to loosen the nut. I also put a short piece of wood under the Basket Drive Block and hit the wood instead of the drive block directly.
Check the clutch bands and springs and the tabs on top of the basket tube and the slots in the basket drive block.
Nov 03, 2009 | Kenmore Washing Machines
The neptune TL model 6800AWW makes a terrible noise at what seems to be the end of the wash cycle. Is this a rebalance? Because it sounds like metal against metal. Or could this be a belt issue. The...
Hello acelmo3,
Thank you for the model number, can you give me the first two digits of your serial number. That number is located on the back right side of the console. I only need the first two digits.10, 12, 16,,,etc.
Let's try to troubleshoot the grinding noise issue, You mention the spin cycle. Have you taken any dc or UC errors in spin cycle? Can you try the following and let me know what you find?
1. Open the lid and rotate tie wash basket by hand Counter Clock Wise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clock Wise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2. (See page 33 of the Service Manual for putty knife insertion point). Also see pic attached.
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. This is what I refer to as a soft failure and possible clean up of the clutch roller bearings in the clutch hub may restore normal clutch operation. A hard failure would be the clutch spring has failed, the roller bearings are rusted beyond clean up. A replacement clutch is required.
Pic attached for top cover removal .
Let me know if you see the tumblers rotating in Spin Only cycle and if yo hear the grinding noise. Rich
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Noise at the *** end of the spin cycle
Hi pils,
As before I am not sure how your machine is built, but what you describe sounds like a problem with either the basket drive block or the brake system.
The basket is going to be mounted to the spin tube with some sort of aluminum adaptor and a nut, at least that's how most all our machines are made. Sometimes the drive block becomes unseated from the drive tube coming up from under the machine and will make a lot of noise when the brake applies at the end of the cycle. This is usually accompanied by the water not being spun out of the clothes as well as it should.
It may be the brake "jumping" when it applies to stop the basket.
What ever it is, it has something to do with the load being reversed when the spin stops. When the machine is spinning, the torque from the motor is transferred through the drive mechanism to turn the basket. When the motor shuts off, this torque is reversed as the momentum of the weight of the spinning load of clothes becomes the driving force and it is transferred back down through the machine until it stops.
Try turning the basket by hand in the direction of the spin and see if you can recreate the noise at at a slow enough speed to be able to pinpoint where it is coming from.
mike
Sep 26, 2008 | Washing Machines
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Calypso Washing Machine
There are two places a coin could be that will cause a noise. Either in the basket under the nutator or in the pump. If you hear the noise after the basket stops from the spin, look under the nutator, if you hear it during the cycle, check the pump. If you only hear the noise during the agitation, not the spin cycle, you may have a u-joint going out.
Oct 02, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Object between drum and spin basket
yes there is but you have to brake apart the hole machine and thats not ease I strongly recomend a tech and pay for this..good luck
Jul 26, 2006 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
309 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
