Question about Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Camera was used in pool. looks like water under lcd. how to remove
How do I use pool pulse?
From the users manual for these pool cleaners:
The Pool Pulse is a flow meter that measures the volume of water flowing through your Zodiac cleaner. It must be used to properly set the flow and can be used as a diagnostic tool when the cleaner isn't running properly.For the following steps, using 2 people is recommended; one poolside and the other at the plumbing manifold. Vacuum and skimmer valves are located at your plumbing manifold.
• Remove the cleaner head.
• Attach the Pool Pulse® to the end of the hose and keep it under water as shown in Figure 1.
• Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool
Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue
indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue
• Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the
extension pipe, attach the hose end. Your installation is now complete.
Apr 30, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
I cannot take pictures because the screen is black...it will not show the view i want to capture...how can i fix this problem? pls help me :(
First of all you need to identify whether your LCD screen is bad or not. You can do this by shooting a picture and downloading it to your PC. If the picture is ok, then your LCD is bad. You need to replace the LCD screen. It is not cheap to replace it.
If your camera is under warranty, try to get it fixed on warranty terms.
A cheaper way, but time consuming. Try to replace the LCD yourself. Remember that you are doing it on your own risk. Warranty becomes void once you open the camera.
Learn some basics from websites. Look at the following web sites:
.http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
If you think you can do it, then buy a jewellers screwdriver set for $1 from Dollar store. Bua a used camera (a similar one sold for parts, but with good LCD) through ebay.com. You have to look for it. You may be able to get it very cheap, may be under $15. Remove the casing on the camera (5-6 screws). Carefully and gently remove the casing, dont break it. Once you open it, usually LCD is immediately accessible.
Jan 18, 2011 | General Electric A950 Digital Camera
How much screen 4 lxus30 canon
Ebay.com is the best place to look for. If you buy the LCD itself it is usually expensive. For example, Try the following email. They replace the LCD: hu221221@gmail.com
But I would suggest you to buy a used camera (one sold for parts, with good LCd) through ebay.com and replace it yourself. You only need to buy a jewellers screwdriver set for $1 from Dollar store. Removing the case is easy (5-6 screws). Once the case is removed, LCD is immediately accessible.
You can buy any one of the cameras:
Canon IXUS 30 40 50 SD200 SD300 SD400
They all use the same LCD. So look in ebay.com for the above cameras. You may be able to get it for under $10-15. But before you do anything look at the following web sites to get an idea on how to do the job:
Jan 18, 2011 | Canon IXUS V2 Digital Camera
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
Camera was soaked in a swimming pool. Nothing works.
It's dead and totally unrepairable then.
Water alone is a camera killer, but chlorinated pool water removes even the remotest possibility of any repair.
Sorry. Not everything can be fixed.
Feb 11, 2010 | Kodak EasyShare LS753 Digital Camera
I am a US Soldier and I bought my Stylus 770 to take to Iraq, I had no problems at all with the camera in Iraq because it was always dry. I am in Jamaica with my wife on or 6 year anniversary trip now...
Stylus 770 is not a perfect water proof camera. it has many gap, so it is not worked properly under water, it works under a small rain only.
I think you should by a new camera. Repair this camera is too much costly. Repair cost is nearly the price of  a new camera.
Sep 24, 2009 | Olympus Stylus 770 SW Digital Camera
After used in beach the camera turns on but no image shows up>
Well it might be waterproof, but it may not include saltwater proof. I think that is the case. If so, then the salt got into your camera and caused something to not work. I would take it in Olympus and let them look at it. It could just be a bad camera.
My guess the lcd screen was faulty or the water leaked in there and shortcircit it.
Sep 09, 2009 | Olympus Stylus 850SW Digital Camera
LG VU GOT WeT!!!!!!
Ok. Heres what happened to me:
I forget my LG Vu (CU920) was in my pocket and I jumped in the pool. I was in the pool for about 10 minutes before I realized. It was full of water. I took the battery out as soon as I realized it. HERES HOW I FIXED IT!!!!!!!!!
Step 1- I took it home, removed the screws on the back panel, and removed it. Now the entire back casing was off.
Step 2- I put the phone and battery (separate) in a bowl of uncooked rice. Sounds crazy but this absorbs all of the water. I left it in there for 2 days.
Step 3- After 2 days, I put the battery back in and everything turned on. Only problem was there was a big bubble in my LCD screen. I then took the phone apart further by popping of the front casing of the phone. I then try to get underneath the LCD to air it out, but I accidentally broke the LCD screen (inside the phone...not plastic outer screen).
Step 4- I went online and purchased a new LCD screen for around $40 from a cel phone parts website. I got it and installed it which was not too hard. You just have to remove all the visible screws (i believe there are 6) from the back side. Then pop off the front cover and the rest is pretty obvious.
Step 5- Put it all back together and it all worked again!
Step 6- My battery soon died after of all this...Im guessing from the water damage. I bought a new one online for around 20 bucks. Now the phone is good as new.
All in all spent 60 bucks and revived the Vu from water damage!!!!!!!!!
Jun 28, 2009 | LG Vu CU920 Cellular Phone
I have a whirlpool refrigerator where water pools under the veggie crispers. It looks like it is coming from the freezer. The unit does not have an ice maker and I suspect a drain line is clogged. Any...
Freezer on top? If so remove rear panel from freezer inside and check drain under evaporator. If clogged, use hot water and turkey baster to squirt water and thaw out drain. DO NOT use sharp instrument to pry ice out. You can use a blow dryer to help thaw as well. Turkey baster helps to jet hot water in drian.
Jun 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
1999 Jeep Wrangler 4 cylinder (manual tran). I noticed a large pool of water in the floorboard on the passenger side of my Jeep. This was after driving for about an hour with the a/c on in Texas at about...
My dad has a 2004 Dodge Dakota with the exact same problem, the passengers side floor board is soaked with water after running the AC. Also there is a pool of water that collects under the truck.
We are getting a mechanic to look at it, I will post what the problem is when we find out.
Jun 25, 2009 | 1999 Jeep Wrangler
Agfa FUJIFILM FINEPIX Z33WP Digital Camera Logo
37 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Larry Stiles
Larry Stiles
Are you an Agfa Camera Expert? Answer questions, earn points and help others
