Question about Ovens
Why does my microwave keep showing F6 readout?
  • 26 Answers
JTP86-30 Oven is not heating. Neither element in the oven heats. I can hear the 'click' I'd expect when it starts to heat. The fan starts up and the readout shows 100 degrees. It never changes and the...
Many GE oven control boards have a relay for the common of the broil and bake elements. This relay is notorious for being the culprit. the electronic control board will need to be replaced. You could check with corecentricsolutions.com to see if the control can be rebuilt. It is much cheaper but you will have to send the board to them for repair.
Mar 28, 2014 | GE Wall Oven Plus Microwave - Model...
HR7 No Electronic Readout
I think it is either a fuse or something that burned out that won't let the display show up. Check all solder points on the inside and see if any are broken for sure. Nothing looks bad does it?
Possibly this is why it was at auction...
Let me know if you still can't figure it out and I will see what else I can come up with.
Thanks
Apr 24, 2008 | Hobart HR7E Electric Single Oven
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
Solutions
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
I am getting an F6 indication in the display window of our Whirlpool microwave oven, what does this mean?
It means problem in timekeeping circuit, remove all power and reset the clock, please let me know if that does the trick.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Whirlpool Ovens
My oven is showing F6 EC TEMP on the screen how do I fix it? Please let me know.
F6: EC (Electrical Compartment) Temperature High
Fault is displayed when the EC thermocouple
exceeds 158?F (70?C). It is monitored once per
minute.
The electrical compartment is overheating. Remove the panel on the right side and clean out all the dust. Check the fan at the back and see if its blowing alot of air. Sometimes this fan can get so clogged up with dirt, it slows down the air flow.
Sep 04, 2010 | TurboChef TORNADO Electric Oven
Microwave display just flashed F6 error code. Only mention in manual is for lower oven display.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and remind us that it displayed an F6 error code.
Nov 26, 2009 | GE JKP85 Electric Double Oven
ERROR F6
HI, the reason for the non responsive control is being caused by a major fault within the control circuits. the entire control board will need to be replaced. it has failed at this point.
Replacing the Oven control board will solve this issue.
Jul 19, 2009 | Ovens
Kenmore model # 911-494-79790
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
May 11, 2008 | Kenmore 30169 Electric Single Oven
Ovens Logo
245 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
