Question about NetGear WGR614 Wireless Router
Limited connectivity with my wireless connection on my laptop--my wife's computer connects fine
  • 1,272 Answers
HI, Follow the steps below to configure the settings:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now please perform the steps below on your wireless computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 27, 2009
Dell inspiron m5030 netgear router
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 23, 2013 | Dell Inspiron Computers & Internet
Computers have limited connection to linksys wrt54g although signal is full strength
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Limited connection
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
May 03, 2012 | Dell Latitude D610 Laptop Computer -...
I have an Acer laptop computer that stopped being able to connect to wife all the way. It says I am connected but then tells me I have limited or no connectivity. Why?
This error occures when your laptop has not been allocated an IP address from your wireless router.
To fix this, right click on your wireless connection on the Task bar and click Repair. The wireless router will then issue a new IP address to the wireless card in your laptop.
Jan 27, 2012 | Acer Computers & Internet
Limited or no connectivity on a laptop
you check your router configuration
your wireless configuration
number o hosts limited
Feb 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
You have to turned on DHCP in your router settings. i think its under the General TAB if its a linksys router
Feb 03, 2009 | Linksys Wireless-G Broadband Router
Getting limited access connection
On her computer, with the USB plugged in. RIGHT click the computer icon with the yellow warning symbol. It's next to the clock in the lower right hand corner of your screen. Then select "Repair."
Sep 21, 2008 | Microsoft RCA CABLE INTERNET MODEM MODLE...
Laptop will not connect to blitz router
Make sure the laptops wireless card has not been turned off. Many laptops have a button where you can turn off the wireless card.
Jul 09, 2008 | Blitzz Technology (BWA611) Router
NetGear WGR614 Wireless Router Logo
114 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
