Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How to replace bad cover switch - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 8,220 Answers
It is best to remove the case so you can easily access the switch" />
Posted on Sep 27, 2009
Replace power window switch
rtm?
read the manual?
the 2008 FSM covers all this. and is complex on 07+ Suzuki's
window failure. 1 window of 4
its not the 1 circuit breaker if motor is 100% dead.
its one of 3 things,
1: bad switch
2: bad motor
3: window jammed overloading motor.
(and as always, bad wiring (conns) to same)
a volt meter finds this easy./
the FSM covers door panel removal and that switch.
or youtube, door panels off. 1million hits.
Jul 08, 2014 | 2008 Suzuki XL7
Turn signal switch replacement
how to....
this is called the combo switch
on many cars, this requires steering wheel removal.
the Jeep FSM covers this in every step.
are your covers off yet? and wheel?
do hazards fail too??????? if yes, remove all lamps and replace them 1 by 1, lamps can short. (excess twisted) and test. 1 by 1.
bad fuse
bad lamps
and last, combo bad.
Dec 04, 2013 | 1988 Jeep Wrangler
Samsung HL-S4676S- changed bulb (as I have before) but new bulb won't come on and still getting flshing LEDs
check the lamp door switch for continuity bewteen the two wire when the switch is in the closed position if thers continuity then the switch is good. If there is no continuity between the two wires with the switch closed then the switch is bad
Jan 01, 2013 | Samsung Televison & Video
I have an optoma ep1691 it has a switch under the bulb cover that tells the projector that the cover is on. It seems to be malfunctioning every now and then, I want to replace it without sending it in. Can...
Its a safety switch to prevent set from being used with door off--to know if it is bad engage it with something not metal (I use a Q-tip or match stick) to know if its bad.
Lever will connect to a switch--you can (not suggested) bypass or jumper that switch for a time to see if the switch is bad---note that if peg that engages the lever is not fully forward (slightly warped door edgewise) this will cause the same issue.
May 29, 2012 | Televison & Video
My neutral light do not come on 2003 883 sportster
It could be either the bulb, wiring, or the neutral indicator switch. The switch is located behind the front sprocket cover. Remove the cover and it's located just forward and down on the side of the case. Unplug the wire from the switch, turn the ignition on, and ground the connector to the engine. The indicator light should come on. If not, you have either a wiring problem or the bulb is bad. If the light does come on, the switch is bad and must be replaced. Hopefully, just the wire is off of the switch.
Good Luck
Steve
Mar 27, 2011 | 2003 Harley Davidson XLH Sportster 883...
1994 ford tauris windshirld wiper switch
Remove plastic cover around column, three or four screw's, then remove three small bolt's on wiper switch same switch as turn signal there together, disconnect harness and remove and replace with new switch, there's no service to switch if bad it just get replace.Hope this was very helpful
Jan 21, 2010 | 1994 Ford Taurus
How do I replace headlight switch in my 95 Pontiac Bonneville
assuming that u have replaced any bad fuses. you have to remove the cover around the instrument panel. then u need to have a socket small enough to remove the screws that hold the head light switch in place. the head light switch knob should come out. you may have to pull it out first before u take the cover off. then remove the old switch and disconect the wires then replace the switch. i hope this helps
Oct 03, 2009 | 1995 Pontiac Bonneville
Timer doesn't Advance.
Shouldn't be slamming the cover, but it can get aggrevating. there is a switch that when you close the cover activates it, could be that the switch is sticking and should be replaced or the timer is acting up, due to loose connection or bad timer. Could check that out also. But what you said it ran till it got to the rinse cycle so my bet is the timer or a bad connection.
Mar 14, 2009 | Kenmore 22622 Top Load Washer
1989 toyota camry blower just stopped
find your fuse layout or owners manual and check the fuse and replace it even if it looks ok,thencheck to see if the switch itself is bad,if so replace it by removing the screws,(4-6) and dash cover checking the connection and switch,replace which ever one is bad and turn on the car,turn one the switch if nothing happens the switch is bad replace and enjoy!
May 18, 2008 | 1989 Toyota Camry
Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Sep 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
129 people viewed this question
Dan Webster
Dan Webster
Sal De
