Home | Bissell | 7901-1 ProHeat Scotchgard Upright Wet... | Hi my proheat bis...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem for Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Hi my proheat bissell 7901 stopped pumping water
By casmodel on Sep 27, 2009
Hi my proheat bissell 7901 stopped pumping water to the floor, but it pumps water from the hand hose. I read the manual and followed how to check belt and the flat belt on right side of shampooer is fine and I turned on and it turns and so do the brushes at the bottom of the machine. I was reading online and I guess there's two belts on this machine? where can I find the other belt to see if it needs replacing. I guess it's a ribbed belt? that is the water pump belt?
Solution #1
posted on Sep 27, 2009
Not Rated)
subdriver
Rank: Master
Rating: 94%, 4 votes
If the unit will pump solution to either location then the pump is ok. (and the belt is a pain to replace)
more than likely either the valve to the floor nozzles is faulty or you have a clog in that path. Follow the clear skinny tubing from the nozzles to the valve. You can trace the solution flow path and find what is stopping it. Good-Luck.
Was this helpful?
Yes
No
Popular Solutions for Bissell 7901-1 ProHeat
Questions and Unsolved Problems for Bissell 7901-1 ProHeat
Do you recommend Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum?
Answer
Answer
I am having problems with my Bissel 7901-1. It isn't working at all. If I remember right it didn't... (More)
Answer
belt assembly diagram. Looking for a picture to see if something is missing holding the belt on.
Answer
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have... (More)
Answer
my bissell cleaner is not picking up the solution and my my knob to switch it from carpets to tools... (More)
Answer
7901 series carpet cleaner sprays but does not **** the water back up. Got it appart right now and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 7901-1 ProHeat...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
