Question about Panasonic KX-FL511 Plain Paper Laser Fax
Fax rollers In my fax machine I have to install new fax rollers but I don't know where to begin.
    Problem Solver:
  • 9 Answers
What kind of roller do you want to install...in feeding unit or in fuser unit?
Posted on Dec 30, 2007
We have a Brothers Intellifax Machine, Model 2820, the problem is with the paper feed, the roller is not grabing the paper to feed it through the machine when we are receiving fax's. I would like to...
there are several fixes to this problem 1. replace pickup asembly 2. Clean the rubber pickup band are roller with a rubber cleaning compound (not alchohol0 alcohol dries out the rubber.
This is a common problem with printers and faxes, Paper has a tendency to leave a glass glaze on the pickup rollers therefore causing the paper to slip on the rollers are to be misfed thus causing a paper jam
Sep 23, 2011 | Brother Office Equipment & Supplies
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
My fax machine (Samsung SCX4720F) is saying paper jam, there is no paper jam. I have taken out the paper and tryed cleaning the rollers and i'm still getting the error.
The problem is not in the rollers.
If you removed all paper and the paper jam error is still on, then the problem is with the paper sensor itself.
This might be reset by a service code (which I don't know) or the sensor may need replacing.
It is not a cheap machine, so you may want to spend some money servicing it.
May 11, 2011 | Office Equipment & Supplies
Phone rings- not receiving faxes- unit copies- paper feeds fine- new toner and roller installed.
try changing the amount of time the fax machine rings before it answers to a low number... if that doesn't work try a reset... info on this page...
Dec 17, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper won't draw
If your Brother Fax machine is an intellifax 2820, or MFC 7220, or the like, it likely just needs to have the pick-up feed rollers cleaned. These are located at the front of the machine where the drawer slides out. In the centre -front of the machine is two rubber rollers. Clean them thoroughly with plain water and a cloth. If this does not work, you may need new pick-up rollers, which most printer service companies should have available and be able to install for little expense.
May 06, 2009 | Brother Office Equipment & Supplies
Faulty fax machine
You can try cleaning that roller with a rag and some rubbing alcohol. Scrub it really good all the way around and that should help.
Aug 02, 2007 | Panasonic KX-FHD351 Plain Paper Thermal...
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
64 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
