Question about Air Tools & Compressors
Model # DD2T2,compressor does not stop,till it bleeds back to 80 pound,pressure switch has been change. should stop at 120 pounds
    President:
  • 1,167 Answers
So buddy what your saying is the compressor stops and then bleeds down a lot of air get back to me
Posted on Sep 27, 2009
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
My compressor comes up to 150 pounds and when it supposed to go to cycle mode it tries to pump again and get stuck between the two modes. it goes cylcle pump cylce pump.
The pressure switch will usually not let the compessor cut back in untill the pressure drops about 20 psi from cut-out pressure. This differntial can be adjusted by turning the differential adjustment screw. I would check that the switch is not faulty first. Look for switch model number under the cover and look for factory cut-out pressure. If the pressure range is different from factory specs, suspect switch is failing, or someone has tried to adjust the pressure. Dont take a chance with possible faulty switch on this expensive compressor. Switch is adjustable but you can replace for about $50. Good luck
Oct 06, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
1997 Chevy S-10 4.3 Vortec a/c blowing hot. Compressor and compressor clutch is working. Charge is up on system. Both low and high side is hot.
Usually when this happens it is the compressor. You really need to have the high and low pressures checked to properly diagnose the problem. You can have the low at 45 pounds and think things are OK, but the high is at 120 pounds. This is a problem. And high a 350 pounds is a problem also.
Sep 03, 2011 | Chevrolet S 10 Cars & Trucks
Have a 6.25hp , 28 gallon stand up. It fell over and bent some of the regulator parts. Got that straight but when you plug it in it does not start up. Un plug and try again...it seams like something in the...
It sounds like the problem that you are having is with the unloader if there is only 30 to 40 pounds of air pressure in the tank it would probably start,but if the pressure is around 90 pounds it would be starting underload, the unloader should exhaust the air from the compressor so it does not have to start underload the unloader does two things it works the magnetic switch to turn the compressor on at probably around 90 pounds and off at about 120 it usually uses 120 V to work your magnetic breaker that uses 240 V I hope this helps.
Feb 19, 2011 | Campbell Hausfeld 28 - Gallon Air...
Ingersoll-Rand DD2T2 air compressor
hi mate its either a fitting off the tank and it is just pumping air into the tank and out the hole or its the mpv valve this stops air in the tank bleeding back to the pump so when the pressure drops it can start other wise it wud not start as the piston is not possible to go up this is why when the compressor stops it bleeds off air in the system but to be honest i need more information to figure out what it could be e.g is it on pump unit or on tank etc
Jul 29, 2009 | Ingersoll Rand DD2T2 T Win Stack Single...
Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Jun 18, 2009 | Air Tools & Compressors
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Poter-Cable 135PSI Pancake Compressor
Check the pressure switch, they can become stuck in the open position. You can jump it to see if it is functioning or use a multimeter if you have one. Assuming that you've oiled and taken care of it it is unlikely that it simly quit, but that could happen... check across the poles of the motor for continuity which will tell you if the electric motor is blown. ALso make sure the compresor is not seized...
Jan 04, 2009 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
